Drive shaft interchangeability
I need drive shafts and I am going to a wrecking yard soon. I have a 92 legacy awd, and the fronts are so bad that it sounds like heard of clydesdales. If I yank accels and a brake caliper, what years are interchangeable (also has ABS)?
pretty sure they will
measure the axles and count the splines in the end of the axle.
I assume you are going to do a cv axle swap correcT?
I imagine 92-96 legacy are all the same size. If you really wanted to know, call a parts store and ask them. I do that to Napa all the time. Just make it sound like your interested in buying from them.
unfortunately I am in hte UK, and in hte north (newcastle) and GOOD parts stores are in short supply. Subes are rare here. which is a bummer. I was going to get axels and rebuild them myself with new boots, then use mine as cores for a new pair when I need them And have the time and money to replace them
