derfster Posted December 2, 2010 Share Posted December 2, 2010 ive put a jdm engine in my 97 legacy gt wagon and it wont start relays and fuel pump turns on and off with key on check engine flashes on and off . Engine justs turns over and over but trys to run sometimes and wont take fuel im comepletely stumped. i alsoput an obd II reader on it and got the following codes p1100 p1101 p1120 p1121 p1540 p130 p136 p 500 Link to comment Share on other sites More sharing options...
lmdew Posted December 2, 2010 Share Posted December 2, 2010 Did you use your old intake and all the sensors? Are you getting spark? If so, put a cap or two of gas in the intake, does it fire now? Double check to make sure the main engine to firewall connectors are dry and tight, no bent pins. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 2, 2010 Share Posted December 2, 2010 given all the codes i would check the connectors. but if the intakes need to be swapped the wiring connector pins may be aligned differently and that will correct everything. P0130 Front Oxygen Sensor Circuit Malfunction P0136 Rear Oxygen Sensor Circuit Malfunction P0500 Vehicle Speed Sensor Malfunction P1100 Starter Switch Circuit Malfunction P1101 Neutral Position Switch Circuit Malfunction P1120 Starter Switch High Input P1121 Neutral Position Switch Circuit Low Input P1540 Vehicle Speed Sensor Malfunction 2 Link to comment Share on other sites More sharing options...
derfster Posted December 3, 2010 Author Share Posted December 3, 2010 given all the codes i would check the connectors. but if the intakes need to be swapped the wiring connector pins may be aligned differently and that will correct everything. P0130 Front Oxygen Sensor Circuit Malfunction P0136 Rear Oxygen Sensor Circuit Malfunction P0500 Vehicle Speed Sensor Malfunction P1100 Starter Switch Circuit Malfunction P1101 Neutral Position Switch Circuit Malfunction P1120 Starter Switch High Input P1121 Neutral Position Switch Circuit Low Input P1540 Vehicle Speed Sensor Malfunction 2 will swaping conectors to those sencors blow my ecu ALSO could my ecu already be blown. Link to comment Share on other sites More sharing options...
derfster Posted December 3, 2010 Author Share Posted December 3, 2010 Did you use your old intake and all the sensors? Are you getting spark? If so, put a cap or two of gas in the intake, does it fire now? Double check to make sure the main engine to firewall connectors are dry and tight, no bent pins. it trys but only runs for a second and then dies gets lots of spark and spark plugs gaped 0.044 in. also theres a hissing sound at left side of engine. at fuel line when fuel pump turns on and is not leakeing or any thing Link to comment Share on other sites More sharing options...
lmdew Posted December 4, 2010 Share Posted December 4, 2010 Sounds like a fuel issue. How long did the car sit? Is the fuel pressure regulator on the passenger side rear fuel rail OK? Pinch off the fuel return line going back to the tank, does it make a difference? Can you hear the fuel pump running? Link to comment Share on other sites More sharing options...
derfster Posted December 4, 2010 Author Share Posted December 4, 2010 Sounds like a fuel issue. How long did the car sit? Is the fuel pressure regulator on the passenger side rear fuel rail OK? Pinch off the fuel return line going back to the tank, does it make a difference? Can you hear the fuel pump running? fuel pressure regulator is on the passanger side i think , Thats where the hissing or gurgleing sound is comming from when key is on I can heare the fuel pump turn on but goes off a second later fuel comes out of return line. the car sat for 1 to 1 and a half years but drained all the gas and put fresh in 2 weeks ago with stabil and sea foam . Link to comment Share on other sites More sharing options...
lmdew Posted December 4, 2010 Share Posted December 4, 2010 Change the pressure regulator. If you need one, I have plenty of them from 2.5. Link to comment Share on other sites More sharing options...
derfster Posted December 5, 2010 Author Share Posted December 5, 2010 Did you use your old intake and all the sensors? Are you getting spark? If so, put a cap or two of gas in the intake, does it fire now? Double check to make sure the main engine to firewall connectors are dry and tight, no bent pins. I used all the sensors from intake I am getting spark tryed the gas runs barly then dies not realy consider a run or start , more like a spuder will check all the wires and connectors Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 5, 2010 Share Posted December 5, 2010 (edited) That's a lot of seemingly unconnected issues. What year was the engine from? Where was this car stored? I'm kinda thinking mouse damage. I just got another wild idea. Check under the dash on the drivers side for the green diagnostic connectors. Those should be left unplugged. If they're connected unhook them. Clicking solenoids and relays sounds like those two connectors are plugged together and the ECU is in self test mode. Edited December 5, 2010 by Fairtax4me Link to comment Share on other sites More sharing options...
derfster Posted December 5, 2010 Author Share Posted December 5, 2010 That's a lot of seemingly unconnected issues. What year was the engine from? Where was this car stored? I'm kinda thinking mouse damage. I just got another wild idea. Check under the dash on the drivers side for the green diagnostic connectors. Those should be left unplugged. If they're connected unhook them. Clicking solenoids and relays sounds like those two connectors are plugged together and the ECU is in self test mode. The engine is a 96 i think i got it on ebay . The car came from south caraolina but the mouse idea might be possable iwill check. i will also check the green wires to thanks and thanks too all who have posted Link to comment Share on other sites More sharing options...
derfster Posted December 5, 2010 Author Share Posted December 5, 2010 Change the pressure regulator. If you need one, I have plenty of them from 2.5. i will check the fuel pressure regulator, thanks for info . Link to comment Share on other sites More sharing options...
