Arty Posted December 3, 2010 Share Posted December 3, 2010 My '95 wagon refuses to spray any fluid. The front nozzles work just fine. I have tried clearing the rear nozzle out with a pin... still nothing. Absolutely nothing works. I'd love to get this stupid thing working. Any ideas? Link to comment Share on other sites More sharing options...
nipper Posted December 3, 2010 Share Posted December 3, 2010 The rear has its own pump in front tank. the pump died. you can use a universal pump kit. You may think about replacing the front pump too, as I had them quit 1 month apart. Link to comment Share on other sites More sharing options...
Arty Posted December 3, 2010 Author Share Posted December 3, 2010 It hasn't worked since the day I got it. I *think* I remember seeing that the pump for the back was in fact working... I think. If this is the case, what next? Link to comment Share on other sites More sharing options...
johnceggleston Posted December 3, 2010 Share Posted December 3, 2010 My '95 wagon refuses to spray any fluid. The front nozzles work just fine. I have tried clearing the rear nozzle out with a pin... still nothing. Absolutely nothing works. I'd love to get this stupid thing working. Any ideas? swap the tube from the upper washer pump, the rear, to the lower washer pump, the front, on the tank. iof the rear squirts when you activate the front washer control, then it is the pump mounted in the tank under the hood. Link to comment Share on other sites More sharing options...
Arty Posted December 3, 2010 Author Share Posted December 3, 2010 swap the tube from the upper washer pump, the rear, to the lower washer pump, the front, on the tank. iof the rear squirts when you activate the front washer control, then it is the pump mounted in the tank under the hood. What if that's not it? Link to comment Share on other sites More sharing options...
johnceggleston Posted December 3, 2010 Share Posted December 3, 2010 What if that's not it? then look at http://www.car-part.com for anew part. the tubes have nothing in them unles it came through the pump. Link to comment Share on other sites More sharing options...
Arty Posted December 3, 2010 Author Share Posted December 3, 2010 then look at http://www.car-part.com for anew part. the tubes have nothing in them unles it came through the pump. No, I mean what if both pumps are working? Link to comment Share on other sites More sharing options...
johnceggleston Posted December 3, 2010 Share Posted December 3, 2010 No, I mean what if both pumps are working? then the tube is disconnected where it jumps from the body of the car to the hatch. just a guess. the pump is bad , check it. that is the weak point. Link to comment Share on other sites More sharing options...
Arty Posted December 3, 2010 Author Share Posted December 3, 2010 then the tube is disconnected where it jumps from the body of the car to the hatch. just a guess. the pump is bad , check it. that is the weak point. Yeah, so... the pump is definitely whirring and the hose in the front is connected. When I hit it, I don't see any fluid dripping, either. If the hose is clogged somewhere, how could I clear it out? I've thought about draining all the fluid from the container and pumping sea foam through it or something. Good idea or bad idea? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 3, 2010 Share Posted December 3, 2010 No you have enough fluid in the tank? I find when it's too low the front will still work (pump longer in tank) but the rear will not. Now since you made this thread I hate this rear washer.. I prefer the spray to be from top to bottom not bottom spraying up. Link to comment Share on other sites More sharing options...
nipper Posted December 3, 2010 Share Posted December 3, 2010 Swap washers see if it pumps. Just because the motor spins it may have enough omph to do anything. Link to comment Share on other sites More sharing options...
Arty Posted December 3, 2010 Author Share Posted December 3, 2010 No you have enough fluid in the tank? I find when it's too low the front will still work (pump longer in tank) but the rear will not. Now since you made this thread I hate this rear washer.. I prefer the spray to be from top to bottom not bottom spraying up. It's completely full. I just want it to work this winter so I can cut the ice with the fluid a bit better. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 3, 2010 Share Posted December 3, 2010 It's completely full. I just want it to work this winter so I can cut the ice with the fluid a bit better. hmm well try what nipper said.. the longest I've had to wait when i first got the car was about 10 secs to purge the line of air. Link to comment Share on other sites More sharing options...
Arty Posted December 4, 2010 Author Share Posted December 4, 2010 I switched the lines like I was told, nothing. I also held the switch for a very, very long time. Nothing. Link to comment Share on other sites More sharing options...
pearlm30 Posted December 4, 2010 Share Posted December 4, 2010 Mine wasnt working, swapped the motor pump and its fine ever since then. Good luck Link to comment Share on other sites More sharing options...
