81ru Posted December 3, 2010 Share Posted December 3, 2010 Colorado Subaru owner looking for suggestions on getting my little ru running. I would really just like to put another engine in, any ideas on where to get a solid one? Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted December 3, 2010 Share Posted December 3, 2010 What's wrong with the current one? Usually not a whole lot goes wrong with the old pushrod engines. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 3, 2010 Share Posted December 3, 2010 We need to know a bit about it - there were two engines used in '81. And as above - these are very dependable and the engines routinely last 350k+ miles when maintained. What's the symptom you are having? GD Quote Link to comment Share on other sites More sharing options...
spazomatic Posted December 3, 2010 Share Posted December 3, 2010 There is a "U-pull" auto parts in Fountain, Co. I haven't been there in a while, but 90% of the time they have at least 1 of 'em in stock. Quote Link to comment Share on other sites More sharing options...
81ru Posted December 3, 2010 Author Share Posted December 3, 2010 What's wrong with the current one? Usually not a whole lot goes wrong with the old pushrod engines. First off it has sat for a year (embarrassed to admit). Before I parked it two main things were going going on: 1. dark blue/gray smoke from the tail pipe. 2. low compression test. sporadic ideal (A friend had rebuilt the carb a year before) but seemed to always have issues with getting the ideal set just right. Noted also that carb is leaking a strong fuel smell when running. Other issues: Engine and transmission leaks: Oil pump leak (something with the switch??) Valve cover caskets Oil pan casket Shift shaft linkage seal Axil boots: Needs both front axils Engine and Trans mount: Pre heat tube missing Wheel barrings: Shot in both front Steering components: Ball joints shot Inner tire rods shot Ive always taken this little vehicle to mechanics and lots of folks have tinkered with it, so I feel very removed from learning about what really might be going on. Looking to educate myself and get under the hood and get this going on my own if I can. Need a tool set and and I honestly feel somewhat overwhelmed with the project. But I don't have the heart to sell this this vehicle. Quote Link to comment Share on other sites More sharing options...
81ru Posted December 3, 2010 Author Share Posted December 3, 2010 There is a "U-pull" auto parts in Fountain, Co. I haven't been there in a while, but 90% of the time they have at least 1 of 'em in stock. Thanks for the information. Quote Link to comment Share on other sites More sharing options...
81ru Posted December 3, 2010 Author Share Posted December 3, 2010 We need to know a bit about it - there were two engines used in '81. And as above - these are very dependable and the engines routinely last 350k+ miles when maintained. What's the symptom you are having? GD[/QUO Where would I find this information? Quote Link to comment Share on other sites More sharing options...
2manetoys Posted December 3, 2010 Share Posted December 3, 2010 The engine model should be embossed on the left side of the motor if your looking under the hood and will say either EA71 or EA81. A pic of the engine compartment will show the difference to those who know. Once they know that, they can be more helpful in diagnosing problems. Quote Link to comment Share on other sites More sharing options...
