81 In need
81ru
  1982gl4 said:
What's wrong with the current one? Usually not a whole lot goes wrong with the old pushrod engines.
First off it has sat for a year (embarrassed to admit). Before I parked it two main things were going going on:
1. dark blue/gray smoke from the tail pipe.
2. low compression test. sporadic ideal (A friend had rebuilt the carb a year before) but seemed to always have issues with getting the ideal set just right. Noted also that carb is leaking a strong fuel smell when running.
Other issues:
Engine and transmission leaks:
Oil pump leak (something with the switch??)
Valve cover caskets
Oil pan casket
Shift shaft linkage seal
Axil boots:
Needs both front axils
Engine and Trans mount:
Pre heat tube missing
Wheel barrings:
Shot in both front
Steering components:
Ball joints shot
Inner tire rods shot
Ive always taken this little vehicle to mechanics and lots of folks have tinkered with it, so I feel very removed from learning about what really might be going on. Looking to educate myself and get under the hood and get this going on my own if I can. Need a tool set and and I honestly feel somewhat overwhelmed with the project. But I don't have the heart to sell this this vehicle.
  GeneralDisorder said:
We need to know a bit about it - there were two engines used in '81.
And as above - these are very dependable and the engines routinely last 350k+ miles when maintained. What's the symptom you are having?
GD[/QUO
Where would I find this information?
The engine model should be embossed on the left side of the motor if your looking under the hood and will say either EA71 or EA81. A pic of the engine compartment will show the difference to those who know. Once they know that, they can be more helpful in diagnosing problems.
