()__1337_CRAYOLA__()> Posted December 6, 2010 Share Posted December 6, 2010 (edited) i have a 95 imp with a ej18 and i want to put a 2.2 short block with the 1.8 heads to keep EGR and dual port exhaust but what years of 2.2 will work with the 1.8 heads out of curiosity. (I did search but couldn't find any info) Heres my work in progress it has, - Ground control coil overs - WRX wheels - WRX front seats - Tinted windows - HID head lights - Rally armor mud flaps Edited December 6, 2010 by ()__1337_CRAYOLA__()> Link to comment Share on other sites More sharing options...
zacyork Posted December 6, 2010 Share Posted December 6, 2010 i think your year had a non-inteference motor so if you get and obd1 2.2 block from lets say a legacy you should be good. i would be worried about obd2 ej22 blocks cause they went to an inteference motor. like 97+ impreza 2.2 Link to comment Share on other sites More sharing options...
Olnick Posted December 6, 2010 Share Posted December 6, 2010 Just to clarify, EJ22 engines from '95 and '96 were OBD-2 AND non-interference. The interference factor (as I understand it) was due to a head redesign for the '97 and later models. Thus any EJ22 short block should work. Someone correct me if I'm wrong! Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 6, 2010 Share Posted December 6, 2010 What I've been reading about building "Frankenmotors" is that the 2.2 and 1.8 heads are mostly the same, the biggest difference is the 2.2 heads flow better. So performance is better with the 2.2 heads. Search for Frankenstein or Frankenmotor and you will find some info about it. The most threads about it are on NASIOC though. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 6, 2010 Share Posted December 6, 2010 Just drop in a '95 or earlier 2.2 - complete engine. There is no advantage to using the 1.8 heads - they are identical (and crappy just like the 2.2 heads). You can use '96 through '98 engines as well if you change to a single port exhaust manifold. The best heads are the '97/'98 single-port heads - they have roller rockers with solid lifters and are good for a little performance boost. The single vs. dual port exhaust deal does not affect performance. GD Link to comment Share on other sites More sharing options...
1982gl4 Posted December 6, 2010 Share Posted December 6, 2010 I have a set of 1.8 heads going on my 2.5. I have to say the heads do not look like they flow as well as the 2.2's as stated above, but it's all I have right now and they were free! The heads you have should fit pretty much any obd1 2.2 block, and some later ones as well. But for that amount of work I would probably just swap in a whole 2.2. Also nice car! I miss my 1.8 brighton coupe a lot! -SB Link to comment Share on other sites More sharing options...
