Loyale 2.7 Turbo Posted September 12, 2011 Author Share Posted September 12, 2011 (edited) This is How I Placed the Oil Catch Can on my Subaru "BumbleBeast" Driver's side to the P.C.V. Valve and smaller Detour to Air Filter: Passenger's side Hose, directly from the Head to the Air Filter Box: I Hope this could be Useful.Kind Regards. Edited October 2, 2016 by Loyale 2.7 Turbo 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 27, 2011 Author Share Posted September 27, 2011 (edited) The Above procedures are for the Carburated EA82's. However, certain EFI EA82's also has problems with their PCV System Sucking Oil, So Subaru made a PCV Re-Route Kit for those models affected with the Original PCV Routing Flaw. Part Number: SUBARU 11813AA010 You can Download a .Pdf file which has the Subaru Recall Info, and the install Procedures, ~► Here. Kind Regards. Edited June 22, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 28, 2011 Author Share Posted September 28, 2011 (edited) Since the Install of the Oil Catch Can, I've Noticed that the EA82 engine on my Subaru "BumbleBeast" suddenly stopped blowing Oil on the PCV System, Not only for the Oil Catch Can... which doesn't has catched a single drop of Oil since the install, but it is a "Side Effect" from the install due two facts, let me Explain: ► The PROPER Routing on the Hoses, Relief the Pressure on the PCV System to Normal, and thus reduces the amount of Blown Oil to the PCV system. ► The 5/8" Hose that comes from the Drivers' side to the Oil Catch Can, is too Long and goes Up so Far, that the small amount of Oil blown, does slide back and return by itself to the Head, so it doesn't reach the Oil Catch Can. Funny, isn't it? Kind Regards. Edited June 22, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 17, 2012 Author Share Posted January 17, 2012 (edited) The Whiter Exhaust Faded away after a week of Driving... Kind Regards. Edited June 22, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 1, 2012 Author Share Posted July 1, 2012 (edited) So, the System Works Perfect and somehow it Keeps Clean itself. Six Months passed already and Not a Single Drop Catched at all...Kind Regards. Edited June 22, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 1, 2012 Author Share Posted July 1, 2012 (edited) Feel Free to Ask Questions. Edited June 12, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Cyfun Posted July 15, 2012 Share Posted July 15, 2012 (edited) So to clarify, you put your catch can between the driver's and passenger's side valve covers? I'm working on some catch can ideas. Was just going to make one out of a jar, but then I considered using this filter/catch can for air compressors from Harbor Break. Not too worried about the filter getting clogged, it's designed to push pretty good volume. And like you said with the eBay catch cans, the pipes seem too small. For $10, we'll find out! I'm actually going to try this first on my mom's Volvo 940 Turbo first, as she gets a disgusting amount of blowby. Mostly happens when I drive it, for some reason. Edited July 15, 2012 by Cyfun Quote Link to comment Share on other sites More sharing options...
kanurys Posted July 15, 2012 Share Posted July 15, 2012 The components of the can do not really filter anything. They help certain oil vapors condense in the can instead of your intake manifold. Before you try to build one, first understand what the PCV system does. The FSM has a great diagram and description. Connecting the two valve covers will do almost nothing. When you understand the PCV system, then you can see that the low pressure on the PCV valve side of the can sucks air/fuel blow-by and oil vapors up to be combusted in the cylinders, again, not to mention all the condensed water in the crank case that gets evaporated at running temp. It does this in certain conditions when pressures on either side of the valve are appropriate. Those oil vapors gum stuff up and need to be captured in the can. Now go study the PCV system and tell us where you think the can should be placed. Quote Link to comment Share on other sites More sharing options...
Cyfun Posted July 15, 2012 Share Posted July 15, 2012 Yeah, the point of a catch can is to catch oil/moisture right before it enters into the intake. So I would imagine that's where you'd wanna put your can. I got that filter catch can from HF, I just need to get some barbed hose fittings that'll fit my PCV hose. Quote Link to comment Share on other sites More sharing options...
kanurys Posted July 15, 2012 Share Posted July 15, 2012 5/8" barb, hose and a few hose clamps shoud do the trick. You want to suck through it right after the drivers side head. (L/H drive) That is, if your system is hooked up properly. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 15, 2012 Author Share Posted July 15, 2012 (edited) So to clarify, you put your catch can between the driver's and passenger's side valve covers? ... No, Absolutely Not. If you read carefully, the First pic explains that it must be Placed between the Driver's Side Head and the PCV on the intake. The Full explanation is, ~► Here. Kind Regards. Edited June 22, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Cyfun Posted July 15, 2012 Share Posted July 15, 2012 Thanks for the write-up, that makes more sense. I'd figure you'd wanna put it right next to where it gets sucked into the intake... Quote Link to comment Share on other sites More sharing options...
HYDE Posted July 31, 2013 Share Posted July 31, 2013 Hey this is an awsome write-up!!! I've just purchased the weber off eBay and I'm ready to start doing the install but for some reason I cant view any of the pics you've posted? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 31, 2013 Author Share Posted July 31, 2013 (edited) Yes, I'm so sad and sorry for that... You can Not see any Pictures because I have uploaded all of them to the Servers of "PhotoBucket" and they have restricted the Bandwidth from 100 Gb monthly, to 10 Gb Monthly, and I'm using their services since year 2003, so you can imagine how many thousands (Literally) of photos I've uploaded there the Last Decade... Photobucket Sucks! See this Thread for Further Details: ~► Here. So you must wait 'till they Reset the Bandwidth each month, to see the Photos... (another way is if I could "Pay" a monthly fee to Photobucket, in order to get unrestricted Bandwidth, but Living in Honduras does it Difficult to me) Kind Regards. Edited August 1, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
tweety Posted August 1, 2013 Share Posted August 1, 2013 On my trike with the EA81 I didnt have blow by issues. The engine had new rigns and bearings 100,000kms (60,000 mls) ago. Then I installed the supercharger. Suddenly I had blow by issues. One sign was the oil dip stick kept popping out of its home, the other was some exhaust smoke. So I installed a catch can. The valve cover on the passenger side (US) should be sucking in air for a source. I chose the air filter assembly. The drivers side going to the PCV is one hose you can place a 'T' piece for the catch can. I then took a second point from the top of the oil filler neck to the catch can. This will all be taken off when going SPFI next week including the SC. Here are some pics. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 22, 2014 Author Share Posted January 22, 2014 ... The drivers side going to the PCV is one hose you can place a 'T' piece for the catch can. I then took a second point from the top of the oil filler neck to the catch can... This setup seems to be Wrong to me, because the Oil Filler tube is on the Passenger's side ® which is the side that breathes fresh air and is the opposite side to where you connected your Oil Catch Can's other end; so it ends to be like connecting both sides together. Think carefully about it. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 26, 2015 Author Share Posted April 26, 2015 Three years and a Half has passed already since I installed the Oil Catch Can on my "BumbleBeast" and I want to Update this thread by saying that the thing hasn't trapped a single drop of oil, because the longer and steep incline route of the hose, prevents the oil to reach the catch can. Funny, isn't it? ... ... Kind Regards. Quote Link to comment Share on other sites More sharing options...
Subasaurus Posted April 26, 2015 Share Posted April 26, 2015 Three years and a Half has passed already since I installed the Oil Catch Can on my "BumbleBeast" and I want to Update this thread by saying that the thing hasn't trapped a single drop of oil, because the longer and steep incline route of the hose, prevents the oil to reach the catch can. Funny, isn't it? ... ... Kind Regards. i just bought the recalled item acouple hours ago, will get here on friday, i think 30bucks for it was alittle pricy but where else am i going to find one unless i make one, plus it was new old stock so i think i did okay.http://m.ebay.com/itm/261697337308?nav=SEARCH Quote Link to comment Share on other sites More sharing options...
