Subi81 Posted February 28, 2004 Share Posted February 28, 2004 Go here and check it out, Click on New Dash http://f1.pg.photos.yahoo.com/ph/subi81@sbcglobal.net/my_photos I was torn about putting an exhaste gas temp in instead of oil pressure, But I would have to weld on a bung and I had the oil pressure gauge around, so there it is. bty this is on the 86 turbo wagon in the sig. Link to comment Share on other sites More sharing options...
torxxx Posted February 28, 2004 Share Posted February 28, 2004 is that plate that you used premade? or did you have to fab it yourself? I want some extra gauges in my car, and i could never find a good spot. That center console spot is a great idea Link to comment Share on other sites More sharing options...
Subi81 Posted February 28, 2004 Author Share Posted February 28, 2004 All hand made, put some miles on the die grinder Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 28, 2004 Share Posted February 28, 2004 wow man that thing looks nice:D Someone put some guages in my 86 turbosedan in the same spot but it looks pretty bad. Maybe I'll have to do something similar to yours so it helps clean it up a bit. Oh and question, how did you get that plate to mount in there? I see the screws but I can't figure it out Link to comment Share on other sites More sharing options...
83projectbrat Posted February 28, 2004 Share Posted February 28, 2004 wow im impressed, that really looks good. i have a 2000 subaru rs and i want the gauges on top my dash.. and i want to buy the subaru guage top thing and fab something so ill need plastic and i was wondering where you got that plastic from? thanks man matt Link to comment Share on other sites More sharing options...
nutt7 Posted February 28, 2004 Share Posted February 28, 2004 if its the same plastic I am thinking of, it is called ABS. any custom stereo shop should have some. they come in like 8" squares. Link to comment Share on other sites More sharing options...
Subi81 Posted February 29, 2004 Author Share Posted February 29, 2004 The black material that I used to mount the gauges to is road sign aluminum, my dad works in construction so he always has road sign sitting around, I think it is 1/16th thick. You can also find this material at a steel supply or OSH or something like that. Thanks nut for the tip on where to find it, I never thought of useing plastic, but it would be easier to work with. First I made an autocad template from some measurements of the opening. Made the drawing as acurate as possible. Printed out the template and glued it on the alluminum, cut it out then trimmed it to fit, took a while. Ah yes the hold down bolts that was a little bit of a streach, basically I made extentions for the bolts with coathangers. Original bolt lenth 1 inch, finished lenght, 6 inches. I cut out the bottom of the storage compartment except for the corners. drilled holes in the corners and put the bolts through the whole shabang! I hope that makes sense, I forgot to take any pics of the altered case. Link to comment Share on other sites More sharing options...
Skip Posted February 29, 2004 Share Posted February 29, 2004 Subi, very clean instal, looks factory. I made a smaller plate and mounted my boost gage, A/F ratio, and digital voltmeter The problem I had was they hard too watch while driving. I remounted them in a A pillar pod and put not quite as often checked gages in it. ( trans temp, fuel pressure, and ammeter) A pillar pod mounts are available at Jegs. Link to comment Share on other sites More sharing options...
subarubrat Posted February 29, 2004 Share Posted February 29, 2004 I DO like that digital..... Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted March 1, 2004 Share Posted March 1, 2004 Wow, looks nice Link to comment Share on other sites More sharing options...
Subi81 Posted March 1, 2004 Author Share Posted March 1, 2004 Ya Skip I totaly agree it is a little bit of a strech to watch them while driving, But I couldn't think of any other place to mount them. I had no idea they made A piller monts that fit subaru trim. Maybe I will have to look into that. Skip where did you get that digital volt meter? that is pretty nice Link to comment Share on other sites More sharing options...
iluvdrt Posted March 1, 2004 Share Posted March 1, 2004 i think the pillar pods are the universal kind. they also sell them at auto zone. i bought one and mounted it, but it didnt look good enough for me so one of my airframer buddies is going to use it as a template to make one out of fiberglass for me. ill let everyone know how it turns out. Link to comment Share on other sites More sharing options...
