ej22 timing belt vs ej25 belt
I don't see how it will be different in terms of size, length, etc. Where it might be different is in its construction. It may be built to go 100,000 miles between change intervals, where most of the ej22 belts are designed for 60,000 change intervals. The exception to this is california spec belts, which I believe are also 100,000 mile change intervals.
  bheinen74 said:
Are the ej22 and ej25 sohc timing belts the same?
I have a used ej22 belt in near new shape, going to put it on my Baja engine if its the same?
Phase 1 EJ22 and Phase 2 EJ25? Or Phase 2 to phase 2? P1 to P2 will not work. P2 to P2 are the same.
