kickascii Posted December 8, 2010 Share Posted December 8, 2010 Isee that advance auto has bearings for $10. Is it worth it to replace that on a perfectly working alternator? Hard? Need a press? Anyone on here done it before? Link to comment Share on other sites More sharing options...
Legacy777 Posted December 8, 2010 Share Posted December 8, 2010 Personally, I probably wouldn't mess with the alternator at this time if it's working ok. I haven't taken apart an alternator, so I'm not sure if the bearings require a press or any special tools. Link to comment Share on other sites More sharing options...
illanrob Posted December 8, 2010 Share Posted December 8, 2010 (edited) Does the whinning stop when warmer, >30DegFah? Can you here it in the cabin with windows up? Edited December 9, 2010 by Legacy777 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 8, 2010 Share Posted December 8, 2010 Just like any motor bearing replacement - a two-jaw puller and a bit of pipe to install the new bearing. Should do the brushes at the same time..... GD Link to comment Share on other sites More sharing options...
johnceggleston Posted December 8, 2010 Share Posted December 8, 2010 i learned recently that an alt will make a whinning noise when it is charging. if the noise ''changes'' with demand, it may be normal. there is a shop here that will rebuild an alt. for 28$ , i think, plus the parts needed. if you are really concerned, take it ot a rebuilder and have it tested. if they a reputable they will tell you the truth, rather than '' oh yeah, good thing you brought it in. it could go at any second.'' from the labor fee, it does not sound like it is too hard to do. but then lots of things are easy the second time. you may have to ask around to find some one who rebuilds. most big electric motor shops don't mess with automotive stuff. at least not around here. Link to comment Share on other sites More sharing options...
nipper Posted December 8, 2010 Share Posted December 8, 2010 there is a shop here that will rebuild an alt. for 28$ , i think, plus the parts needed. The parts are incredibly expensive, it makes a rebuilt from Subaru lok like a steal. I wouldnt worry about noises when the car is cold (and the air temp is cold) as long as they go away once the car warms up. Now if it was doing it at 40 degrees or more then I would wonder about it. How many miles and what year is the car (that should always be given) Link to comment Share on other sites More sharing options...
kickascii Posted December 10, 2010 Author Share Posted December 10, 2010 It's a 1996 Impreza Brighton with 260k on it. I would say it's not a whine, it's a screeching noise that seems to only do it the first couple minutes after startup. It almost sounds like the noise you get when you spin something too fast and it starts frea'kin out. Does that help? I drive it to work 30% of the time and it's 90 miles round trip. Charges fine and is not a "whine" like when an alternator is charging heavily. Link to comment Share on other sites More sharing options...
nipper Posted December 10, 2010 Share Posted December 10, 2010 Original Alt? Link to comment Share on other sites More sharing options...
Ionlyhave3suubs Posted December 11, 2010 Share Posted December 11, 2010 There is a local shop in Roanoke,VA that rebuilds, but if you are looking for a cheap fix, you might do well to check with some members for an alt from a car being parted out. The rebuild is not impossible for someone who has never done one, but like with anything, it is much easier if you have someone helping you that's done it before. Not sure if you are ever near Roanoke, but if you are interested, they do good work, usually 2 day turnaround though. They have done a couple of alternators for me. Usually about half the cost of a rebuilt from Advance. PM me if you want me to get you their contact info. Link to comment Share on other sites More sharing options...
nipper Posted December 11, 2010 Share Posted December 11, 2010 (edited) WOWZERS! Alternator, Alternator Impreza List Price : $691.04 Your Price : $580.48 Quantity: Alternator, Bearings FRONT, Impreza List Price : $23.60 Your Price : $16.99 Quantity: Alternator, Bearings REAR, Impreza List Price : $38.92 Your Price : $28.02 Quantity: Alternator, Brushes Impreza List Price : $4.82 Your Price : $3.47 Quantity: Alternator, Rectifier Impreza List Price : $148.22 Your Price : $106.72 Quantity: Alternator, Rotor Impreza List Price : $302.92 Your Price : $218.10 Quantity: Alternator, Stator Impreza List Price : $207.58 Your Price : $149.46 Quantity: Alternator, Voltage regulator Impreza List Price : $198.65 Your Price : $143.03 I will never understand why these alts are so expensive! Blus (1998 Outback) was 99.00 from subaru! rebuild it! Edited December 11, 2010 by nipper Link to comment Share on other sites More sharing options...
987687 Posted December 12, 2010 Share Posted December 12, 2010 As GD said, replacing the bearing isn't very difficult. Getting the alt apart though... Is a little bit of a pain in the rump roast. I took an old EJ one apart to replace the reg. Just make sure you mark everything for re-assembly, takes a lot of the guess work out of it. Link to comment Share on other sites More sharing options...
nipper Posted December 12, 2010 Share Posted December 12, 2010 Since the brushes are cheap, I woudl replace them as long as I am there. Link to comment Share on other sites More sharing options...
kickascii Posted December 15, 2010 Author Share Posted December 15, 2010 Since the brushes are cheap, I woudl replace them as long as I am there. thanks for all the ideas.. i may just end up calling some salvage yards for some sub-100k mile cars... it might be about the same price and less work. Link to comment Share on other sites More sharing options...
kickascii Posted December 15, 2010 Author Share Posted December 15, 2010 1993 Alternator Subaru Impreza 1.8,COL-AOD,5/93 C 10G083 $45 Ernie's Auto Enterprise, Inc. USA-WV(Martinsburg) Request_Quote 304-274-1133 Request_Insurance_Quote 9 miles away Link to comment Share on other sites More sharing options...
