78 Brat loosing coolant in 4X4
I'd say your cooling system is inadequate. Does the electric fan come on?
I used to have the same problem with my 81. The fan didn't come on, and crawling around in 4wd not only makes the engine work harder, but because you're not moving fast there's not enough airflow through the radiator.
Failing that, make sure the radiator, water pump and thermostat are working as they should.
