nipper Posted December 28, 2010 Share Posted December 28, 2010 ALWAYS replace the pressure plate. The spring gets tired and they are part of a clutch kit Quote Link to comment Share on other sites More sharing options...
Goobysoobs Posted December 28, 2010 Share Posted December 28, 2010 yeah they are part of the clutch kit but the kits are about 80 or so less without the pressure plate but I guess I'll get it with it. What springs though wear out? The little finger things? Quote Link to comment Share on other sites More sharing options...
nipper Posted December 28, 2010 Share Posted December 28, 2010 The long heading is if someone does a search on this they can find it. yeah they are part of the clutch kit but the kits are about 80 or so less without the pressure plate but I guess I'll get it with it. What springs though wear out? The little finger things? The plate itself can get hardspots and no one machines them. Those little fingers are called a bleville spring and do get exposed to heat. They actually apply more force halfway through the disc's life. After that point they loose the clamping force. Towards the end of the discs life they will start to slip (before you can tell) and heat up. When you can finally tell they get rather hot. They also need to be a matched set as they are balanced together. You can just replace the disc if there is very little mileage on it (ie a failed oil seal). Clutch Assembly 101. http://books.google.com/books?id=U4TBoJB2zgsC&pg=PA905&lpg=PA905&dq=belleville+spring+pressure+plate&source=bl&ots=MUSQVrNIqh&sig=US2FieCeupO1W9tM-8RcRGFcn3o&hl=en&ei=jTQaTYA2goLyBt30zKQD&sa=X&oi=book_result&ct=result&resnum=9&ved=0CFEQ6AEwCA#v=onepage&q=belleville%20spring%20pressure%20plate&f=false Start at page 900 . Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 29, 2010 Share Posted December 29, 2010 Great link Nipper. Gonna read some of that myself... tomorrow... zzz Quote Link to comment Share on other sites More sharing options...
