soobenthusiast Posted December 13, 2010 Share Posted December 13, 2010 We recently acquired a 92 Loyale sedan that has the key broken off in the ignition. How should I get the cylinder off or get the key out? Thanks Link to comment Share on other sites More sharing options...
LegacyBrad Posted December 13, 2010 Share Posted December 13, 2010 Buy a set of key extractors, shoot a bit of lube ( like wd40) in there and use the tools to pull it out. Instructions: Link: http://www.clksupplies.com/shop/product_info.php?cPath=197&products_id=1187 Good luck. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 14, 2010 Share Posted December 14, 2010 ...or Remove the Entire ignition Switch to Work with it. Link to comment Share on other sites More sharing options...
soobenthusiast Posted December 14, 2010 Author Share Posted December 14, 2010 Ok, Got the key out, now we just need to find a way to get another key. Link to comment Share on other sites More sharing options...
edrach Posted December 14, 2010 Share Posted December 14, 2010 Ok, Got the key out, now we just need to find a way to get another key.That part is easy. Some dealers still can make you an original key from the VIN number (bring your ID and proof of ownership). If that doesn't work, remove the door card from the passenger side front door and gain access to the door lock cylinder. Using a flashlight and mirror copy the key number off the cylinder (something like W334) and take it to a quality locksmith who can make a master key from that number. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 14, 2010 Share Posted December 14, 2010 ...Also you can... ... remove the door card from the passenger side front door and gain access to the door lock cylinder. ... ...and Take the Whole Lock Cylinder to a Locksmith; I did That Long time ago and Worked Very well. That Works 'cos the Locksmith uses the Actual position of the Lock Cylinder to Cut a Whole New Key, with the Advantage of Testing it Right There. Kind Regards. Link to comment Share on other sites More sharing options...
