nickolai Posted December 14, 2010 Share Posted December 14, 2010 Hi, I'm rebuilding my ea81 and am at the stage of buying the bearings and rings. I would like to save as much $$$ as possible but don't want to use junk parts either. What do you guys think of Clevite bearings? Cause they're on ebay for like $12. Any feedback appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 14, 2010 Share Posted December 14, 2010 Clevite makes good bearings. I have them in my small block chevy lol. In fact they are really the only bearing that my machine shop uses. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 15, 2010 Share Posted December 15, 2010 .... What do you guys think of Clevite bearings? Cause they're on ebay for like $12. Any feedback appreciated. Thanks. Clevite has been around quite awhile. I did a quick search on eBay and only found undersized bearings. I bring this up just in case you overlooked sizing. Quote Link to comment Share on other sites More sharing options...
nickolai Posted December 16, 2010 Author Share Posted December 16, 2010 Thanks for the input. I've asked a couple people locally too and it sounds like the Clevite bearings are pretty decent. As for sizes, undersize is what I need. The crankshaft was pretty scored so I had it turned down to .25mm main, and .50mm rod. I was just wary of finding them so cheap when they're like $46 on Rockauto.com. Quote Link to comment Share on other sites More sharing options...
nickolai Posted December 23, 2010 Author Share Posted December 23, 2010 Okay so these are the parts I'm looking at buying: rings http://cgi.ebay.com/ebaymotors/Subaru-Brat-Loyale-Piston-Ring-Set-4-Cyl-76-94-1781cc-_W0QQcmdZViewItemQQhashZitem27b6eacad5QQitemZ170572565205QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories main bearings http://cgi.ebay.com/ebaymotors/Subaru-1800-Brat-1800-XT-Turbo-New-Main-Bearings-_W0QQcmdZViewItemQQhashZitem4839414904QQitemZ310198225156QQptZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories rod bearings http://cgi.ebay.com/ebaymotors/Subaru-Rod-Bearing-set-OVERSIZE-1300-1600-1972-1984-_W0QQcmdZViewItemQQhashZitem3a5aa39ae7QQitemZ250628774631QQptZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories Am I finding great deals or am I looking at cheap junk? Thanks for the input so far. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 23, 2010 Share Posted December 23, 2010 Rod bearings are listed as for 1400 and 1600 (EA61? and EA71) engines, with no mention of working on 1800 EA81s. Might want to check into this. Main bearings say they are oversize rather than undersize. Simply a nomenclature issue, or are these for resized bearing saddles? Quote Link to comment Share on other sites More sharing options...
howpow Posted December 23, 2010 Share Posted December 23, 2010 Hi NorthWet. I'm looking for oversize bearings for resized bearing saddles, do you happen to know if they are available. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 23, 2010 Share Posted December 23, 2010 Hi NorthWet. I'm looking for oversize bearings for resized bearing saddles, do you happen to know if they are available. I have been following your thread. I will respond there to prevent hijacking this thread. Quote Link to comment Share on other sites More sharing options...
nickolai Posted December 23, 2010 Author Share Posted December 23, 2010 Rod bearings are listed as for 1400 and 1600 (EA61? and EA71) engines, with no mention of working on 1800 EA81s. Might want to check into this. I asked the seller if he had bearings for my engine and he said these will fit an ea81 also. I have seen other listings saying they will fit anywhere from ea61 to ea82. Main bearings say they are oversize rather than undersize. Simply a nomenclature issue, or are these for resized bearing saddles? Are you saying there is a difference between undersize/oversize? I asked locally and was told there is not. Undersize is referring to the size of the crankshaft, while oversize refers to if the block has been bored larger? Also, regardless of these details, do these look like quality parts? Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 24, 2010 Share Posted December 24, 2010 I reread the rod bearing posting, and the vendor did clarify that these would be for a machined crankshaft (making them "undersized"). Probably right on the main bearings being the same for EA61/EA71 and EA81. (Got to love parts commonality!) Rod bearings are clevite, main bearings are indeterminate but probably decent, and rings are from a common maker/distributor so should also be decent. Quote Link to comment Share on other sites More sharing options...
Idasho Posted December 24, 2010 Share Posted December 24, 2010 Are you saying there is a difference between undersize/oversize? Of course there is a difference. Undersized is needed when the crank shaft surface is machined. Oversized is needed when the connecting rod journals are machined. If neither has been machined, you need standards. I always use a bit of emery cloth to polish the surfaces prior to installing new bearings too. And can I ask why you are so hung up on buying motor parts like bearings off of ebay?? Rockauto has these clevite connecting rod and main bearings available. It might cost a bit more but you know you are getting the correct parts. Quote Link to comment Share on other sites More sharing options...
nickolai Posted December 24, 2010 Author Share Posted December 24, 2010 I reread the rod bearing posting, and the vendor did clarify that these would be for a machined crankshaft (making them "undersized"). Probably right on the main bearings being the same for EA61/EA71 and EA81. (Got to love parts commonality!) Yes I have been saved by interchangeable parts numerous times. Rod bearings are clevite, main bearings are indeterminate but probably decent, and rings are from a common maker/distributor so should also be decent. Thanks for the help. I just purchased all three items. I get what I get I guess. Quote Link to comment Share on other sites More sharing options...
nickolai Posted December 24, 2010 Author Share Posted December 24, 2010 Of course there is a difference. Undersized is needed when the crank shaft surface is machined. Oversized is needed when the connecting rod journals are machined. Thanks for the clarification. And can I ask why you are so hung up on buying motor parts like bearings off of ebay?? Rockauto has these clevite connecting rod and main bearings available. It might cost a bit more but you know you are getting the correct parts. Just thought I would save some money if they are the same brand part. Rarely am I unsatisfied with ebay items. Quote Link to comment Share on other sites More sharing options...
STiAMV Posted May 29, 2016 Share Posted May 29, 2016 I asked the seller if he had bearings for my engine and he said these will fit an ea81 also. I have seen other listings saying they will fit anywhere from ea61 to ea82. Are you saying there is a difference between undersize/oversize? I asked locally and was told there is not. Undersize is referring to the size of the crankshaft, while oversize refers to if the block has been bored larger? Also, regardless of these details, do these look like quality parts? Will raise the topic and ask , dealt with the sizes? bearing crankshaft ЕА81 from ЕА82 different sizes ? Quote Link to comment Share on other sites More sharing options...
TomRhere Posted May 30, 2016 Share Posted May 30, 2016 EA81-EA82-ER27 share the same main/rod bearings. Same rods and piston rings also. 1 Quote Link to comment Share on other sites More sharing options...
jono Posted May 30, 2016 Share Posted May 30, 2016 same rings as some Volvos too !! Quote Link to comment Share on other sites More sharing options...
