henerythe8th Posted December 15, 2010 Share Posted December 15, 2010 I had a doj go bad on my 87. Had a helluva time trying to get the axle unmated from the wheel end. An errant smack, or two, with a BFH and I bent the piss out of the sheet metal bearing protector that presses onto the end of joint. Anyone got an idea what it's actually called and/or where to source one from? Your help is appreciated. My first post! Thanks to those that posted before... ...your help is very much appreciated. I finally got to the point that I cursed the appropriate amount to get the shaft off... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 15, 2010 Share Posted December 15, 2010 You don't really need that dust sheild - just lube up the splines with anti-seize and call it good. I don't even run those sheilds on my lifted wagon. Typically you can just straighten them and put them back on - if you need a new one then your best bet is a junk yard since it's that's not somthing prone to failure. GD Quote Link to comment Share on other sites More sharing options...
