Good Headgasket Article and questions.
http://allwheeldriveauto.com/subaru-head-gasket-problems-explained/
Thought is was some interesting reading as I'm in the market for a late 90's Outback.
Is there any way to tell if the gaskets have been done? Other then asking the current owner? Does anyone have any tips not covered in the article for assessing the condition of the head gaskets? I'm hopng to go look at an outback this weekend, I had two Legacy wagons previously but both had the 2.2.
Thanks!
Jared
Edited by jclay
Undoubtedly you will receive some timely info. I would suggest you also search "head gasket" or "EJ25 head gasket" . There have been recent threads to where with an inspection lite you could determine whether they were "newer improved" gaskets. The fellow (i don't even have an ej25) mentioned certain tabs which are prominant and where they stick out and stuff. good luck
yes you can visually look at the headgaskets to see if they've been changed.
you should ask the current owner. if anything you get a quick read on how honest/shady they are. if it's a dealer then you can explain the prevalence of the headgasket issue on this motor.
