ncwillus Posted December 17, 2010 Share Posted December 17, 2010 Hey guys, My 97 legacy was running fine for awhile and one day went to go crank it to warm up and it made this very prompt squeak then it was shuttering like. well i came back later and once i did, it still was sputtering and it smoked a bit. very low power, any ideas what it may be? Link to comment Share on other sites More sharing options...
Legacy777 Posted December 20, 2010 Share Posted December 20, 2010 It may have been a timing belt idler pulley bearing, and the belt may have jumped a tooth, which could be causing your low power and sputtering. How many miles are on the car and when was the last time the belt has been replaced, or any other routine maintenance? Link to comment Share on other sites More sharing options...
ncwillus Posted December 21, 2010 Author Share Posted December 21, 2010 I had a belt put on recently and it has 200k miles and some change. Last night though my friend brought over his computer and it pulled the codes P0341&P0400&P0507. I am curious if those will fix my problem. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 21, 2010 Share Posted December 21, 2010 I had a belt put on recently and it has 200k miles and some change. Last night though my friend brought over his computer and it pulled the codes P0341&P0400&P0507. I am curious if those will fix my problem. PO341 Camshaft Position Sensor Circuit Range Problem P0400 Exhaust Gas Recirculation Flow Malfunction P0507 Idle Control System RPM Higher Than Expected Link to comment Share on other sites More sharing options...
bstone Posted December 21, 2010 Share Posted December 21, 2010 All of those can be causing your problems. Fix them. Link to comment Share on other sites More sharing options...
ncwillus Posted December 22, 2010 Author Share Posted December 22, 2010 yeah im gona try these first see what happens, ive replaced the EGR many times so guess we will see. Link to comment Share on other sites More sharing options...
