Yo'J Posted December 20, 2010 Share Posted December 20, 2010 Ball joints and radius rod bushings are easy to fix together. I would just do both at the same time for the ease of labor. Its nice to know they are done. Subies have a 'little bit' of torque steer too. A steering rack issue would show itself when braking by steering wheel wobble. Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 20, 2010 Share Posted December 20, 2010 Pulling during accel and deccel is from a change in caster measurements. When the tire shifts back under accel, the caster lowers on that side causing the pull to go to that side. I would bet its going to be either ball joints or radius rod bushings. I almost never see a wobble caused by an alignment under braking. Its usually a pulsating rotor. If the rack bushings were the culprit, the OP would complain of the steering wheel being off center after going through a hard turn, will usually be off to the side they were just turning. If the tie rods/ends were worn out, it would cause a toe out issue while driving straight and cause the steering wheel to be off center as well. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 22, 2010 Share Posted December 22, 2010 Ionlyhave3suubs said: It's gotta be the muffler bearings:lol:, ... Muffler Bearing? ... see: http://www.ultimatesubaru.org/forum/showthread.php?t=56844&page=4 Link to comment Share on other sites More sharing options...
KristjanJohann Posted December 23, 2010 Share Posted December 23, 2010 Well, didn't want to run through the whole thread, but I have three theories and I know one of them is right... Tiresize or pressure balancepole bushings And the thing my 86 leone went through, bushings for the diff, I got myself some hard POM plasting bushings and my car stopped turning left or right when pulling or letting off Link to comment Share on other sites More sharing options...
TeamCF Posted December 23, 2010 Share Posted December 23, 2010 Uncle Ed said: Well, thats one good guess from Northwet. Another would be the steering rack mount rubber has slipped out and is letting the rack move up and down which changes the toe-in.Ed I've had that happen on mine as well on one side. It did do the pulling either way while accelerating/decelerating. Also it gave a loud clunk at times during steering and getting on and off the gas. After it happened a couple times in a row. (I had to fix it almost every time I took it out) I took the bracket that clamps it down and layed a couple weld beads along it to give it a bit of bite into the rubber. Grips great now and the rubber bushing has not slipped out in over a year. Link to comment Share on other sites More sharing options...
TPain Posted December 24, 2010 Author Share Posted December 24, 2010 Thanks for all the info guys, I really appreciate it. So where's the ball joint located again? Link to comment Share on other sites More sharing options...
NorthWet Posted December 24, 2010 Share Posted December 24, 2010 Between the bottom of the front knuckle and the control arm. Link to comment Share on other sites More sharing options...
TeamCF Posted December 24, 2010 Share Posted December 24, 2010 Yeah big thing is just poke around under there. Any worn out/loose part of the front suspension or steering could cause all kinds of alignment issues that can change depending on if you are braking or accelerating. So check anything you can get your hands on. And be sure to just check for loose bolts too. Never know. Could be that easy. Good luck. Link to comment Share on other sites More sharing options...
PNO TECH Posted January 9, 2012 Share Posted January 9, 2012 Had to chime in here for anyone else who searches these symptoms. My 87 GL wagon EA82 would pull hard to the right on acceleration, then veer left when I let off the go pedal. The right outer tierod joint had stripped threads: only thing holding it on the car was the cotter pin. D'oh! I still have it hanging on my wall of shame. Scot Link to comment Share on other sites More sharing options...
gooner1800 Posted January 16, 2016 Share Posted January 16, 2016 Mmmm, this sounds like the same problem my '93 DL wagon has - pulling to the left on acceleration but straight as a ruler off the gas...I guess I should be looking for a problem on the lefthand tie rod end? Link to comment Share on other sites More sharing options...
spazomatic Posted January 22, 2016 Share Posted January 22, 2016 Im going to suggest tightening the axle nut. I chased a similar problem in my 84, and tightening the nut on the end of the axle (runs through the hub) fixed it. Link to comment Share on other sites More sharing options...
