DanteC Posted December 20, 2010 Share Posted December 20, 2010 Im wondering what the biggest tires i can run on my stock-geared 96' legacy. Its got an ej22, manual 5 spd. Im cutting the fenders, i lifted it 2", and am planning on wheel spacers. i already bought 15" rims and i was planning on running some 235/75/r15's, or some 31x10.5 a/t's i have from my truck. But im not sure if i'll have any torque left. Anyone have experience? besides a D/R swap, is there anything i can do? do other subies have lower geared diff's i can swap in? Link to comment Share on other sites More sharing options...
idosubaru Posted December 20, 2010 Share Posted December 20, 2010 front diff is part of the trans i'm sure you know so a simple diff swap isn't really an option....i mean you can swap front diffs but that's a rather huge job that no one has ever really done just to change gearing. simpler to just swap a trans you want. it'll take a hit but not sure what would bother you, if it at all. you looking for offroad or onroad performance? around town driving, racing, or interstate driving? my buddy lifted his 97 EJ22 MT legacy with OBW struts and put larger wheels & tires and i believe he said he now has to down shift to 4th some for climbing mountains on the interstate that he never had to do before all that. so it looses a little - but that's at highway speeds too with greater aspect ratio due to the lift. Link to comment Share on other sites More sharing options...
newsoobdude Posted December 20, 2010 Share Posted December 20, 2010 (edited) 235s will require a bit of trimming in the rear to clear the wheel wells. I'm lifting my 98 Outback a little over 4 inches overall and am only going 225s. You will be loosing a lot of low end torque with the larger tires too. I'd say go with a good set of 215s/ 27s and Outback struts as well as your lift and go to town. A Delta cam would help with the low-end torque return as well as a better exhaust. Edited December 20, 2010 by newsoobdude Link to comment Share on other sites More sharing options...
DanteC Posted December 21, 2010 Author Share Posted December 21, 2010 This is strictly a trail rig, it was a car i got for free due to it being rolled a few times, so im just making a beater. however i would still like some low end. How bad will it be? Link to comment Share on other sites More sharing options...
91 subaru Posted December 23, 2010 Share Posted December 23, 2010 i put 235's on my 91 loyale with no lift(as of yet) and the power and torque both fine. still drives the same all the way around Link to comment Share on other sites More sharing options...
DanteC Posted December 24, 2010 Author Share Posted December 24, 2010 91 subaru said: i put 235's on my 91 loyale with no lift(as of yet) and the power and torque both fine. still drives the same all the way around exactly the answer i wanted to hear. Thanks! Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 24, 2010 Share Posted December 24, 2010 91 subaru said: i put 235's on my 91 loyale with no lift(as of yet) and the power and torque both fine. still drives the same all the way around Does that Tires Rub? ... I'll Love to See Pictures... Could you Post any? Link to comment Share on other sites More sharing options...
91 subaru Posted December 24, 2010 Share Posted December 24, 2010 Loyale 2.7 Turbo said: Does that Tires Rub? ... I'll Love to See Pictures... Could you Post any? Dont get me wrong i had to cut the front and back edge of the fenders with a lil bit of hammering. U cant just slap on a 235 and do nothing else. i hope this goes to the pics. http://www.ultimatesubaru.org/forum/showthread.php?t=118642 The tires are baldining tires as pointed out. Remember that there is no lift on this car. wouldnt be a good idea to put good tires on it... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 24, 2010 Share Posted December 24, 2010 Thank you for your Kind Answer... My EA82 Weberized Wagon now Runs with 205/60 R 15 (25") without Rubbing, I made Somehow a Custom 2" Lift just by Swapping the Suspension, as you can Read here: http://www.ultimatesubaru.org/forum/showthread.php?t=110546 Your Subie does Look Good with those Chrome Rims... My other Wagon (the ER27 engined one, now Crashed as you can Read here) has a Set of Chrome Rims too... Kind Regards. Link to comment Share on other sites More sharing options...
91 subaru Posted December 24, 2010 Share Posted December 24, 2010 I have a set of 225 75 15's (with the tread on them) that im gonna put on. they should fit alot better. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 24, 2010 Share Posted December 24, 2010 91 subaru said: i put 235's on my 91 loyale with no lift(as of yet) and the power and torque both fine. still drives the same all the way around Loyale (ea82) and legacy are 2 different animals, the lagacy strut will be your limiting factor, get a set of OUTBACK struts which will allow 27-28" tire, non-OUTBACK will not allow for much bigger then stock, Link to comment Share on other sites More sharing options...
DanteC Posted December 24, 2010 Author Share Posted December 24, 2010 Scott in Bellingham said: Loyale (ea82) and legacy are 2 different animals, the lagacy strut will be your limiting factor, get a set of OUTBACK struts which will allow 27-28" tire, non-OUTBACK will not allow for much bigger then stock, I noticed that, i was planning on wheel spacers. Link to comment Share on other sites More sharing options...
