Where to find pug lugs?
Depends on the steel wheel. The 504 Steelie uses a really bizarre one. The alloy ones in my opinion are all the same or interchangable but still not compatible with a Subaru nut unless you use the spacer/adapter. Some folks recommend using longer studs with some of them as well as there aren't a bunch of threads to spare here and the wheels are thicker than most Subaru wheels.
