HATCHY Posted December 25, 2010 Share Posted December 25, 2010 I was curious if anyone has run or is running a 6al msd ignition box on their GL. I ran a blaster coil before but it kept wrecking my distributor,?? Im not sure if the gls run a 12 to 18 volt system,. I know they work on vw bugs, I dont see why they wont work on subaru , I was also planning on running the nissan 90 amp alternator as well.. if that makes a diffence. thanks for advise Link to comment Share on other sites More sharing options...
AWD TURBO! Posted December 25, 2010 Share Posted December 25, 2010 yes they work I'm using one Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 26, 2010 Share Posted December 26, 2010 I'll Love to See Pics of that Setup! ... More info Needed. Link to comment Share on other sites More sharing options...
7point62fmj Posted December 26, 2010 Share Posted December 26, 2010 Mic brat is also running one of the MSD6's on his car. Not sure which one. Link to comment Share on other sites More sharing options...
HATCHY Posted December 26, 2010 Author Share Posted December 26, 2010 Sweet. I've been wanting one for awhile. Did you have to Do any modifications or plug and go. And did you wnotice any diffence in power or combustion e Link to comment Share on other sites More sharing options...
AWD TURBO! Posted December 28, 2010 Share Posted December 28, 2010 (edited) yep rat nest i just used the 4 wires +- to the coil & the +- from the harms this box is the digital with the built in rpm limiter set at 5700 i like it Edited December 28, 2010 by AWD TURBO! ps dont use sold core wires like taylor's like the ones i'm useing Link to comment Share on other sites More sharing options...
phantomD Posted December 28, 2010 Share Posted December 28, 2010 Hang on, what's this about blaster coils killing distributors? I was about to fit one to mine... Link to comment Share on other sites More sharing options...
HATCHY Posted December 28, 2010 Author Share Posted December 28, 2010 Oh you have a fuel injected. The box will still work on a carbed engine right. I have a ea81. And about the distrubutor popping I'm not sure why. But the accell coil didn't do it only the blaster two. Strange. Could be I just had bad distys e Link to comment Share on other sites More sharing options...
mcbrat Posted December 28, 2010 Share Posted December 28, 2010 7point62fmj said: Mic brat is also running one of the MSD6's on his car. Not sure which one. I'm running a 6A on a weberized ea81, along with an Accel SuperCoil (square block kind). I really noticed a difference when I did mine... been running it for years now.... Link to comment Share on other sites More sharing options...
HATCHY Posted December 28, 2010 Author Share Posted December 28, 2010 right on mc brat, I like the msd box, and everything it does,. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 29, 2010 Share Posted December 29, 2010 HATCHY said: ... and everything it does,. Could Someone Please explain what is Exactly Everything it Does? ... That's New for me. Link to comment Share on other sites More sharing options...
mcbrat Posted December 30, 2010 Share Posted December 30, 2010 Loyale 2.7 Turbo said: Could Someone Please explain what is Exactly Everything it Does? ... That's New for me. it's a multi-spark ignition box. supposed to make sure you get a full burn.... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 30, 2010 Share Posted December 30, 2010 Thank you for your Kind answer... That's New Stuff for me. I Run my EA82 Weberized Wagon with an Accel (Made in USA) SuperStock 8140 High Vibration Coil, that Surpasses the Stock Coil's Output... I've been Runnin' it since some years ago and it works Great, but that MSD Stuff sounds even more Accurate. Kind Regards. Link to comment Share on other sites More sharing options...
maozebong Posted December 31, 2010 Share Posted December 31, 2010 i have an msd 6a in my 93 prelude project car. i really love it. cold starts are easier and the entire powerband is smooth. if i come across another msd box im gonna be throwing it in my soob. just not wanting to pay 100 for another :-\ although, ive heard the msd ignition boxes do not work with accel for some reason... wonder why? Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted January 1, 2011 Share Posted January 1, 2011 maozebong said: although, ive heard the msd ignition boxes do not work with accel for some reason... wonder why? probably something to do with the coils resistance....i know the Delphi dual curve ignitions that used to be common here on dual fuel LPG/petrol conversions where quite sensitive to trying to drive a coil with a resistance that was different to what they where designed to operate with Link to comment Share on other sites More sharing options...
ferp420 Posted July 20, 2012 Share Posted July 20, 2012 Where did you guys get your pick up signial from I can't figure out what wire it is Link to comment Share on other sites More sharing options...
maozebong Posted July 21, 2012 Share Posted July 21, 2012 just put it inline on the coil wires... one connects to coil neg and the other to coil positive. i think the coil negative might be the signal?? not 100%, but if you hook it up backwards nothing will go bad. also, obviously, disconnect the stock wires from the stock coil and then put the orange and black wires from the MSD box that are for the coil, on the coil. the red and white wires will be connected to the stock coil wires. Link to comment Share on other sites More sharing options...
ferp420 Posted July 27, 2012 Share Posted July 27, 2012 Ok that was to easy thanks Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 27, 2012 Share Posted July 27, 2012 HATCHY said: ... And about the distrubutor popping I'm not sure why. But the accell coil didn't do it only the blaster two. Strange. Could be I just had bad distys e As far as I Know, the Accel SuperStock ignition Coil has almost the Same Resistance (Ω) Values than the Stock Nippon Denso Ignition Coil (I guess that also the Hitachi Ignition coils has around the Same Values too), while the MSD Blaster has increased resistance values, which damages the Ignition Module on the Distribuitor. Kind Regards. Link to comment Share on other sites More sharing options...
