Looking for P/W Fuse & or breaker
Trying to help my brother in law out. His 92 Legacy's power windows don't work. None of them. I have been trying to figure out where the fuse or breaker and relay are that the manual suggests should be there and I can't find them. Are they in the door or under the dash? Does anyone have a link to a picture or diagram of where they are?
Thanks,
Stephen
I'll bet that the master switch (driver's door) has gone bad. That's the most common thing, but its a good idea to check the fuse first. The easiest thing to do is to pull the master switch out of the driver's door panel and make sure there's power up to it. Then check to make sure there's continuity through all 4 switches. My guess is it has died.
Found it and the problem. Both wires were totally corroded out of the connector to the Circuit Breaker. In fact, one of the spades in the connector broke out and is still buried in the female and I can't see it through the blue corrosion. :( I have a hunch that might be the problem.
Thanks for the help.
Stephen
p.s. kind of a stupid place to put it IMHO
