ghost Posted December 29, 2010 Share Posted December 29, 2010 (edited) Im looking around a bit and trying to find some answer but i just generally see that for 27" tires, the common is 2" with some cutting possibly required or 3" with a tight fit correct? I hope to get some generic steel wheels that are 6 lug. Most likely 15"x7" with 3.5 inch backspacing. I know those are super common. I used to have a lifted Geo Tracker and i have 2 sets of tires here around that size (they were the stock ones, i had 235/75/R15 on the Tracker). One set is from my Tracker and i have a set of brand new General Altimax HP's off my moms old junk Maxima (they're lower profile though, 205/65/R15) I know most decent A/T tires come in the 205/75 for a good price too, so i think thats what ill shoot for when i lift my rig. Im aiming for a no cut solution since my Subaru is in pretty fantastic shape in terms of rust and damage to it. Im thinking maybe a full 3" lift to get all the extra goodies put on (like, not just the strut spacers, have a complete kit dropping crossmembers and everything else.) That is, unless a 2" will work ok for those tires. Edited December 29, 2010 by ghost Quote Link to comment Share on other sites More sharing options...
Uberoo Posted December 29, 2010 Share Posted December 29, 2010 what vehicle? for EA81: 4-6" lift is typically needed to clear 27" without cutting For Ea82 2-4" lift EJ stuffs 2-3" lift Quote Link to comment Share on other sites More sharing options...
ghost Posted December 29, 2010 Author Share Posted December 29, 2010 Ah, i forgot. EA82, its an an 87 GL turbo. If i could get away with 2" and no cutting that would be awesome. For the set of 205/65/R15 I assume id be ok with a 2" lift (they measure out to about 25.5") but moving up to my 205/75/R15 i may hit some rub. Quote Link to comment Share on other sites More sharing options...
one eye Posted December 29, 2010 Share Posted December 29, 2010 A 2" would work good for that, I have an 85 wagon with a 2" lift and 27's on it with no cutting................ Jeff Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 29, 2010 Share Posted December 29, 2010 I'm putting a set of 205 75 15's on my Brat with a 3" lift. But they only measure about 26.5-26.7" tall. I fit 26.25" tires with a 2" lift in the front and just the torsion bar cranked in the rear, so I'm pretty sure the extra little bit will fit fine Quote Link to comment Share on other sites More sharing options...
987687 Posted December 30, 2010 Share Posted December 30, 2010 I have 205/75/14s on my GL with a 2" lift, so just a bit smaller than what you want. They fit just fine. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 30, 2010 Share Posted December 30, 2010 I have 205/75/14s on my GL with a 2" lift, so just a bit smaller than what you want. They fit just fine. Yeah and those are the ones that measured 26 1/4 when they were new Quote Link to comment Share on other sites More sharing options...
ghost Posted December 30, 2010 Author Share Posted December 30, 2010 From the lifted Soob 2010 topic I found this one, owned by brysawn: 2" homemade lift 6-lug hubs using toyota studs toyota 4runner sr5 wheels General grabber at2 in 205/75/15 http://i32.tinypic.com/30m8srb.jpg Thats pretty much the exact look i want and the wheels are coincidentally the exact ones i found locally(but they may prove troublesome due to needed both new studs and lug nuts) Quote Link to comment Share on other sites More sharing options...
brysawn Posted January 5, 2011 Share Posted January 5, 2011 I'm putting a set of 205 75 15's on my Brat with a 3" lift. But they only measure about 26.5-26.7" tall. I fit 26.25" tires with a 2" lift in the front and just the torsion bar cranked in the rear, so I'm pretty sure the extra little bit will fit fine A 205/75/15 should be a 27.1" tire, minimum. From the lifted Soob 2010 topic I found this one, owned by brysawn: 2" homemade lift 6-lug hubs using toyota studs toyota 4runner sr5 wheels General grabber at2 in 205/75/15 http://i32.tinypic.com/30m8srb.jpg Thats pretty much the exact look i want and the wheels are coincidentally the exact ones i found locally(but they may prove troublesome due to needed both new studs and lug nuts) I returned your message about the wheels. Its very easy to get these to fit. The tough part is finding a store that will have 24 of the studs you need, be prepared to drive to a bunch of different O'reilly's Quote Link to comment Share on other sites More sharing options...
bratman18 Posted January 5, 2011 Share Posted January 5, 2011 A 205/75/15 should be a 27.1" tire, minimum. sorry, but mine are brand new, and they measure between 26 1/2 and 26 3/4. All tire manufacturers are different when it comes to tire size. I have found that with many tires.:-\ Quote Link to comment Share on other sites More sharing options...
brysawn Posted January 5, 2011 Share Posted January 5, 2011 sorry, but mine are brand new, and they measure between 26 1/2 and 26 3/4. All tire manufacturers are different when it comes to tire size. I have found that with many tires.:-\ Yeah that is very true. I was just going off of the metric conversion. Quote Link to comment Share on other sites More sharing options...
ghost Posted January 5, 2011 Author Share Posted January 5, 2011 I returned your message about the wheels. Its very easy to get these to fit. The tough part is finding a store that will have 24 of the studs you need, be prepared to drive to a bunch of different O'reilly's Thanks very much brysawn! I was searching for studs and did see they had 2 different parts for front and rear. You're saying i need the ones with the longer spline thread right? Otherwise, due to the thinness of the hub compared to the Toyota hub they go in, the wheels wouldn't get tight by not having enough threads correct? Yea, I think the studs are about $1.80 or $2 depending on which part is the correct one. Now all i have to do is find some 4Runner or Yota Truck lug nuts. That shouldnt be too hard, but that im only speculating. The tires that are going on it are going to be 205/65/R15's General Altimax HP's off my moms non running Maxima. They should fit fine if you're running 205/75's. Quote Link to comment Share on other sites More sharing options...
brysawn Posted January 6, 2011 Share Posted January 6, 2011 Thanks very much brysawn! I was searching for studs and did see they had 2 different parts for front and rear. You're saying i need the ones with the longer spline thread right? Otherwise, due to the thinness of the hub compared to the Toyota hub they go in, the wheels wouldn't get tight by not having enough threads correct? Yea, I think the studs are about $1.80 or $2 depending on which part is the correct one. Now all i have to do is find some 4Runner or Yota Truck lug nuts. That shouldnt be too hard, but that im only speculating. The tires that are going on it are going to be 205/65/R15's General Altimax HP's off my moms non running Maxima. They should fit fine if you're running 205/75's. No, you need to make sure that you get the SMALLER shoulder, if you get the longer of the two, it sticks through the hub and the lug nut will bottom out on the shoulder of the stud before you are able to tighten on the wheel. And for the studs, just go to Les Schwab and ask for their used lug nuts. Tell them what you need and they should have tons of them. I got all 24 of mine for 20 bucks. And yes, those tires should fit. I had to trim a little with my tires though. Quote Link to comment Share on other sites More sharing options...
