swilde20 Posted December 30, 2010 Share Posted December 30, 2010 I just bought a 97 Legacy gt that the guy was in way over his head and now i'm thinking i might be also. He put in a JDM motor and drove the car about 10.000 miles and developed a hesitation, when a idle the engine runs perfect. When you try to speed up you get a hesitation and a little bit of a chuging, but at certain rpms it does smooth out and run good. I have a flashing check engine light and the code comes up p1101 Manufacture control fuel and air meter. also have 2 other codes po500 speed sensor a and po325 knock sensor 1 bank 1. Anyone have any ideas. Thanks Steve Link to comment Share on other sites More sharing options...
swilde20 Posted December 31, 2010 Author Share Posted December 31, 2010 No ideas, common even an educated guess would be ok. Link to comment Share on other sites More sharing options...
naru Posted December 31, 2010 Share Posted December 31, 2010 P1101Neutral Position Switch Circuit High Input (A/T) P1101Neutral Position Switch Circuit Malfunction (M/T) Check plugs and wires for the hesitation. Link to comment Share on other sites More sharing options...
swilde20 Posted January 5, 2011 Author Share Posted January 5, 2011 No one else has any ideas? Link to comment Share on other sites More sharing options...
johnceggleston Posted January 5, 2011 Share Posted January 5, 2011 P0325 -Knock Sensor Circuit Malfunction the hesitation could be the knock sensor. mine was old and tired and caused hesitaion under slight load, driving uphill. if i punched it it would eventually catch and go. mine did this for a while before it threw a code. P0325 is actually a circuit problem that could be a connector or corrosion under the sensor, maybe. but depending on the miles, it may be due anyway. P0500 - Vehicle Speed Sensor Malfunction any speedo issues? does the AWD work properly? if it is an auto trans, put the FWD fuse in and take a test drive. see if you can feel a difference. i usually can. P1101 - Neutral Position Switch Circuit High Input (A/T) P1101 - Neutral Position Switch Circuit Malfunction (M/T) i have no idea about the last one? but it too sounds like a circuit issue? Link to comment Share on other sites More sharing options...
