wagonist Posted November 5, 2014 Share Posted November 5, 2014 On 11/1/2014 at 6:46 PM, Loyale 2.7 Turbo said: I bet that those tiny threaded holes are intended for placing the Base for a Switch, but I am almost Sure that such Switch was Not intended for the Factory Halogen Lamps, because the Factory Switch for those Halogens, came on the Dashboard; as you can see it in previous posts of this thread, also here: So, could those be intended to mount a Switch for some kind of Factory Alarm System? Actually, that isn't the "factory" switch for the front fog lamps, it's for the dealer fitted option fog lights (tho it might be for American specs cars) The factory fitted one (well at least JDM) sits in the bank of 6 beside the cluster between the steering wheel & door. Its the bottom left switch on RHD. I'll try to get a pic of the S1 version I've got at home. It has to be that because the series 1 GL wagons had a separate locking switch for the tailgate (which smart people remove because it allows you to break into the car in about 4 seconds ) It's a possible fitment on Series 2, but I've seen a full spec JDM turbo wagon with it still up the top, and not in the position where this switch should go. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 5, 2014 Author Share Posted November 5, 2014 (edited) On 11/5/2014 at 1:51 AM, wagonist said: ...The factory fitted one (well at least JDM) sits in the bank of 6 beside the cluster between the steering wheel & door... Yes, I Agree... I've seen it also, but please share the photos here. I was referring to the "Automatic Cover" Halogen Lamps, So it was my mistake for not explaining that I thought that the Switch pictured above, must be for the Halogen's Automatic Cover, Also that same switch came on the Subaru Alcyone XT6. Or could those Automatic Cover Halogens, had another switch in another placement? I see a Rocker switch between the Halogen Lamps in the photo above, but it could be Aftermarket... Kind Regards. Edited November 5, 2014 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 5, 2014 Author Share Posted November 5, 2014 I thought that the Switch powered the Automatic Cover, because it bears the same symbol from the Older Switches that Powered the Cover on the Third-Eyed EA81's, See: On 12/8/2013 at 5:20 PM, Loyale 2.7 Turbo said: I've seen in other threads, Photos of Switches for the "Third Eye" Lamps, a feature for the Second Gen Leone / Brat; the emblem at the middle of the Grille, tilted to show a Hiding Halogen; these are some of said Switches for such lamp, also known as Passing Lamp: But the Day I found a Subaru GL-10 Turbo Sedan on a Local Junk Yard, I grabbed many of its parts... With same Symbol than the Third Eye ones above.. Anyone has more information about that? Kind Regards. Link to comment Share on other sites More sharing options...
dp213 Posted November 6, 2014 Share Posted November 6, 2014 What about the cyclops headlight option they had on brats. I am working on a brat and the guy has a cyclops grill he wants me to install. Also this brat has flip up ttops. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 6, 2014 Author Share Posted November 6, 2014 On 11/6/2014 at 2:22 PM, dp213 said: What about the cyclops headlight option they had on brats... The photo of Three switches together, belongs to that "Cyclops" Headlight option, on Brats and other EA81 Models from that Era. Link to comment Share on other sites More sharing options...
wagonist Posted November 11, 2014 Share Posted November 11, 2014 Found some on the Ausubaru forum Series 2: Series 1 (a bit harder to see, but also on the bottom left): The automatic covers are simply that, automatic. You press the switch and the power for the light raises the cover. When the power is disconnected, they lower. The only extra wire is permanent power for the motors. 3 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 12, 2014 Author Share Posted November 12, 2014 On 11/11/2014 at 10:11 PM, wagonist said: Found some on the Ausubaru forum... The automatic covers are simply that, automatic. You press the switch and the power for the light raises the cover. When the power is disconnected, they lower. The only extra wire is permanent power for the motors. That makes sense. Thank you for sharing the Photos and the information, So the Switch pictured above, which I found on an Early Local GL-10 Turbo EA82 Sedan, Could have been a Dealer installed Fog Lights... that switch was also used on XT / XT6 as far as I know. Kind Regards. Link to comment Share on other sites More sharing options...
wagonist Posted November 12, 2014 Share Posted November 12, 2014 Or they took the kit meant for an XT. I've got that. A friend wanted the yellow fog lights, and I wanted the harness & switch. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 12, 2014 Author Share Posted November 12, 2014 I like the '80's decade look, that this louvers provide to the Subaru Leone RX Turbo 1 Link to comment Share on other sites More sharing options...
wagonist Posted November 12, 2014 Share Posted November 12, 2014 That RX looks so mint. Recently gave one of those louvres to someone else who helped me out. I think another mate still has the touring wagon version I had (he bought the wreck of a car I wrote off). I should get it back from him... Very 80s & very Australian Link to comment Share on other sites More sharing options...
rrgrr Posted January 8, 2015 Share Posted January 8, 2015 This Ski Carrier for the Loyale...Anyone have these on their car? 1 Link to comment Share on other sites More sharing options...
Hsoj Posted January 8, 2015 Share Posted January 8, 2015 On 11/11/2014 at 10:11 PM, wagonist said: Found some on the Ausubaru forum Series 2: Series 1 (a bit harder to see, but also on the bottom left): Is that Height button for the hydraulic suspension we didn't get here in the states? It would be nice to see the flip up lights on the ea82! Link to comment Share on other sites More sharing options...
ford'ssubaru's Posted January 8, 2015 Share Posted January 8, 2015 All you guys are awesome in this thread. I learned so much......Most productive thing I did all day. Guess I had better clock out.....LOL. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 8, 2015 Author Share Posted January 8, 2015 (edited) On 1/8/2015 at 11:29 PM, ford'ssubaru's said: All you guys are awesome in this thread. I learned so much.... Thank You! On 1/8/2015 at 10:22 PM, Hsoj said: Is that Height button for the hydraulic suspension we didn't get here in the states? ... I'm not sure if the Hydraulic suspension was available in USA, seems like Very Few of the Older models might got that ... ... I recall a thread about one EA81 with Hydraulic Suspension here; The rest that came with "Height" adjust, had Pneumatic suspension. Kind Regards. Edited January 9, 2015 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 22, 2015 Author Share Posted February 22, 2015 The second gen Subaru Rex, a front engine, two cylinder mini car that later inspired the creation of the Subaru Justy; is a very special Car, the ones who own one of those in Honduras, said to me that they'll never sell their Rex, because it usually never fails and moves with the mere "Odor" of the Gasoline... The Subaru Rex could be considered a 3/4 Justy, despite that the Rex was built before the Justy. The Subaru Rex was the Front Wheel Drive only model, while the same car but with 4WD, was known as Subaru Sherpa. Let me share here, a couple of photos of local (Honduran) Subaru Rex: Recently, I found a List of optional accessories, available in Australia, for that Subaru: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 22, 2015 Author Share Posted February 22, 2015 Original Subaru Paint "Touch-up" Pencils, anyone? 1 Link to comment Share on other sites More sharing options...
wagonist Posted February 23, 2015 Share Posted February 23, 2015 On 1/8/2015 at 10:22 PM, Hsoj said: Is that Height button for the hydraulic suspension we didn't get here in the states? It would be nice to see the flip up lights on the ea82! no, it was the switch for the pneumatic suspension. Which was ditched a while ago due to the airbags being too expensive to buy from Subaru. Flip up lights? You mean like on the XT/Vortex? urggh I think the nose of those is way too long 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 23, 2015 Author Share Posted February 23, 2015 On 2/23/2015 at 7:52 AM, wagonist said: ... Flip up lights? You mean like on the XT/Vortex? ... The Flip Up Lights on third gen Leone / Loyale, are the extra Halogens with "Automatic Cover" The cover itself is the "Flip up" part, not like the XT or XT6. Kind Regards. 1 Link to comment Share on other sites More sharing options...
NocturneVoyager Posted March 11, 2015 Share Posted March 11, 2015 For rare parts, I found an accent piece that I've heard is pretty rare. I'm going to someday get the top of my dash done (it has nasty sun splits in it), and when I do, I actually have a brand new replacement bezel piece for the front (where it wraps around the vents, radio, instruments) for my 86 XT. Gonna wait until it's ready, and then get the new beauty face put on that baby! Only 125K miles, but dang..........still going STRONG! Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 12, 2015 Author Share Posted May 12, 2015 1 Link to comment Share on other sites More sharing options...
comatosellama Posted May 12, 2015 Share Posted May 12, 2015 On 5/12/2015 at 5:21 PM, Loyale 2.7 Turbo said: I need that one on the left, lol Link to comment Share on other sites More sharing options...
comatosellama Posted May 12, 2015 Share Posted May 12, 2015 On 11/6/2014 at 2:22 PM, dp213 said: What about the cyclops headlight option they had on brats. I am working on a brat and the guy has a cyclops grill he wants me to install. Also this brat has flip up ttops. What do you mean by flip up T-tops? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 13, 2015 Author Share Posted May 13, 2015 On 5/12/2015 at 5:47 PM, comatosellama said: I need that one on the left, lol No, those keys aren't mine, they belong to Nico: ~► http://www.ultimatesubaru.org/forum/topic/126559-retro-gl-10-turbo-build/page-15?do=findComment&comment=1227066 Seems like they were offered in Japan, sometimes they shows on e-bay. Kind Regards. Link to comment Share on other sites More sharing options...
zombieblues Posted May 13, 2015 Share Posted May 13, 2015 On 12/31/2010 at 9:08 PM, 1982gl4 said: These wheels. I have only seen a couple of other sets. Love them on both my Brat and Wagon I have these rims but they are painted white. And I only have 3 Anyone wanna buy 3 of these??!? Link to comment Share on other sites More sharing options...
comatosellama Posted May 13, 2015 Share Posted May 13, 2015 On 1/14/2011 at 11:56 PM, Flowmastered87GL said: A one owner Baja (ya I know it says old school part.... but I have a brat logo on my Baja so it counts) I saw a baja with a topper on it yesterday. I just sat there and drooled Link to comment Share on other sites More sharing options...
