Yeah..that is the Alarm part of the 'keyless entry system'. I've had both - one with and one without. The alarm is an additional upgrade to the keyless system....there is a probably one of these under the hood:
As I keep waiting for lightning to strike, I'll offer this respetful disagreement w/Nipper - the Red light is also a button....I believe the description of its function above is correct - o - mundo.
And under the driver's side dash is the other button - brown (or black) - that allows the key fobs/remotes to be programmed and to turn off the alarm when the battery is disconnected>>reconnected.
GL,
Td
GL,
Td
I agree, I think that CODE ALARM used the led/valet switch but I haven't seen one in a long time.
I believe it is a factory unit (added by the dealer) which I believe were made by Code Alarm with a subaru part number.
  Rooster2 said:
My 98 OBW has the flashing light alarm system. I never knew that the light is also a push button. Pushing the button does what in valet mode?
The mode shuts off the alarm for the car wash, the mechanic, and the Valet incase they park the car with the keys in it.
If anyone would like a PDF of this manual for further reading, PM me with an email address.
Copied directly from the manual on my old 2000 2.5RS:
The status indicator/Valet button
HS1004BB
The Status Indicator is a high intensity warning light, located on the
dash to the left of the steering wheel. The Status Indicator displays a
visual indication of the security system’s status while creating a powerful
theft deterrent.
LED status
Off: System is disarmed.
Double-Flash: System is in valet mode.
Steady Flash: System is armed.
Fast Flash: System has been triggered.
On: System is in pre-arm state (and will arm when all doors are
closed).
n The valet button (built into the status indicator)
The Valet Button is used to engage Valet Mode (see “Valet mode”
Section). In Valet Mode, the security system will not arm, through the
siren will chirp and keyless entry features will function when the security
system is disarmed.
HS1004BB
theft deterrent.
LED status
closed).
system is disarmed.
Thanks Duania
Now I just have to decipher how to shut the dang thing off...I have no fob...so when I attached the battery, the doors autmatically locked...i don't want that to happen
