lmdew Posted January 4, 2011 Share Posted January 4, 2011 My Brothers 97 Impreza OBS has the flashing AT Temp Light, 16 times and torque bind. When he put the FWD fuse in, the FWD light did not come on. This tells me it's the C-Duty solinoid. If you are in SE WI and have changed one of these before, you help would be appreciated. I've changed them and they are not that hard, but if it's your first time it can be difficult. A heated shop is available for the work. Lmdew@hotmail.com Quote Link to comment Share on other sites More sharing options...
wtdash Posted January 4, 2011 Share Posted January 4, 2011 Larry, Did he confirm the TB didn't change w/the FWD fuse in (in case the light is burnt out)? Just would want to make sure it's the Duty-C and not the clutches....although it has to be opened up either way. GL, Td Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 4, 2011 Author Share Posted January 4, 2011 I don't know that he drove it, I think he just started the car in the driveway. Good thought though. Thanks Quote Link to comment Share on other sites More sharing options...
xbeerd Posted January 4, 2011 Share Posted January 4, 2011 (edited) we're over in SE WI, i havent dug into the duty C solenoid at all on these, but i think its right up inside the trans fluid pan. IE. remove fluid, remove trans fluid pan, remove and replace solenoid? where you located? EDIT: nevermind, read the next post! Edited January 4, 2011 by xbeerd Quote Link to comment Share on other sites More sharing options...
hush777 Posted January 4, 2011 Share Posted January 4, 2011 Not inside the pan. You have to drop the exhaust and the drive shaft out and then take the rear housing off to get to the solenoid and the clutches. just did this on my outback sport. Not any where close to you though, sorry. Hush Quote Link to comment Share on other sites More sharing options...
xbeerd Posted January 4, 2011 Share Posted January 4, 2011 OH. thanks for the clarification, that sucks! Quote Link to comment Share on other sites More sharing options...
bstone Posted January 4, 2011 Share Posted January 4, 2011 There is a garage on the north side of Chicago open 24/7. http://dagostinoautoservice.com/ You can rent a bay there and even pay one of the mechanics to help. I worked at this garage (but in school during the year). It's not too far from SW Wisconsin and you can do the job in one night. I started at 11pm and finished at 6am when replacing my Duty C Solenoid. Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 4, 2011 Author Share Posted January 4, 2011 He's in Watertown, the heated shop is in Sullivan, WI just off I-94 west of Milwaukee. I'm sure he could do it, I just know from doing this in the past it's much easier the second or third time. Thanks, Larry Quote Link to comment Share on other sites More sharing options...
