jackinthecrack Posted January 4, 2011 Share Posted January 4, 2011 (edited) Its labeled "check engine" Edited January 4, 2011 by jackinthecrack Link to comment Share on other sites More sharing options...
johnceggleston Posted January 4, 2011 Share Posted January 4, 2011 scan tool connection maybe?? is it under the dash driver's side.? Link to comment Share on other sites More sharing options...
jackinthecrack Posted January 4, 2011 Author Share Posted January 4, 2011 Well.....thats just it, its in a van Supposed to be all 04 forester stuff. but I have no ODB2 port to speak of. Link to comment Share on other sites More sharing options...
bison118 Posted January 4, 2011 Share Posted January 4, 2011 Doesnt look like an OBD2 plug to me....But i only have a quarter of technician school under my belt, so i could be wrong Link to comment Share on other sites More sharing options...
jackinthecrack Posted January 4, 2011 Author Share Posted January 4, 2011 Deff not an OBD2 port. Anyone got ideas? Link to comment Share on other sites More sharing options...
johnceggleston Posted January 4, 2011 Share Posted January 4, 2011 when i said scantool, i was thinking the ''subaru scantool'' or whatever they call it, which does diagnostics and some programming of the computer. i didn't think / know it plugged into the OBD2 port. i don't even know if they still have them. but the connector in question looks kind of like one under my dash, drivers side, mounted onto the center console thingamajig / hvac / radio whachamacallit. those are technical terms. take a look. Link to comment Share on other sites More sharing options...
zacyork Posted January 4, 2011 Share Posted January 4, 2011 Well.....thats just it, its in a van Supposed to be all 04 forester stuff. but I have no ODB2 port to speak of. so im confused what are you working on? you have a 2.5 swap in a van? Link to comment Share on other sites More sharing options...
jackinthecrack Posted January 4, 2011 Author Share Posted January 4, 2011 Yes, its an 86 vanagon (westy camper) Woulda posted this over in the conversion section...not alot of action over there. Link to comment Share on other sites More sharing options...
Fuzpile Posted January 4, 2011 Share Posted January 4, 2011 Jack are U being obtuse? It's not OBD11 or 1 . There was a service plug in Mopars around 1979 that looked like that. A "big box" analyzer could get spark and timing, rpm info off it ...i'm just rambling because it's some dingo dash component. Link to comment Share on other sites More sharing options...
jackinthecrack Posted January 4, 2011 Author Share Posted January 4, 2011 HMM, I am having difficulties finding the correct wires for my OBD port....its been hacked/cracked to death. I keep having high idle issues but when I disconnect the battery and back again it clears the issue till it warms up then back to high idle...so I would GUESS this is going in to a fault mode. Link to comment Share on other sites More sharing options...
ShawnW Posted May 17, 2012 Share Posted May 17, 2012 I haven't ever seen a code that makes the car have a higher idle than before. The grey plug referenced above is a diagnostic plug for the HVAC system I believe. I have never used it, and worked as a Subaru dealer technician in the past. If your harness was modified by a company-they should have left the OBD2 plug in it. Its possible they left that plug in-and chopped the OBD2 plug by mistake. It would not be easy to add back in. It would be easier to modify another harness. But it would have to be a harness that works and matches that VIN number in every way, otherwise you would end up with a bunch of ghost codes, that you can detect and read, but no way to get rid of them. There is a VIN number stamped into the side of the engine block. Its very hard to read and if the shortblock was replaced at any time in the Subaru vehicles life it might not be there-or could be the wrong VIN. Feel free to call me about this if you need help, another harness modified, etc. Link to comment Share on other sites More sharing options...
