NoahDL88 Posted March 1, 2004 Share Posted March 1, 2004 Sorry for the yelling, but i ran in to a big problem when swapping my engine out. I was planing on useing an EA-82 carby intake but it dosn't clear the coolant hose that goes to the block under the carburetor, so i have run into a big problem as you can see. Now i have a question, can the Weber adaptor from the EA-82 fit on the EA-81 manifold? cause if it can thats great, if its not i need a new adaptor and intake manifold. and to make matters worse spring vacation starts in one week, so i need it by wednesday if possible, so Austin, if you got one spare, that would be great, even better if its got the adapter plate. The Quick and dirty I need an EA-81 Carby manifold and a weber 32/36 adapter plate Thanks in advance to anyone that has one!! Link to comment Share on other sites More sharing options...
Ratty2Austin Posted March 1, 2004 Share Posted March 1, 2004 I am fresh out of adaptor plates, but I have a good selection of ea81 manifolds.... just let me know what your looking to do- Link to comment Share on other sites More sharing options...
WJM Posted March 1, 2004 Share Posted March 1, 2004 id make a hose work with the EA82 manifold. Link to comment Share on other sites More sharing options...
mcbrat Posted March 1, 2004 Share Posted March 1, 2004 you have mail Noah. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 1, 2004 Author Share Posted March 1, 2004 thank you McBrat for such wonderful mail So after i wrote this i remembered that i need a dip stick tube, not the dipstick but the tube that goes into the block, there wasnt' one on the engine when i got it, and other than that i think i have everything, thanks to a girlfriend that dosn't mind making trips to part stores. Link to comment Share on other sites More sharing options...
CIS Subaru Posted March 1, 2004 Share Posted March 1, 2004 What engine are you trying to put the EA82 manifold on? The High-Po EA81? How exactly does it not fit? I was planning to use an EA82 carb on one of my EA81 projects, so I'm very curious. Link to comment Share on other sites More sharing options...
mcbrat Posted March 1, 2004 Share Posted March 1, 2004 Priority Mail sent. will arrive Wednesday. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 1, 2004 Author Share Posted March 1, 2004 thanks, Mcbrat. Noah, the other manifold won't work cause the coolant tube next to the thermostat hits the vacuume advance, and there is also the usual issue of the accelerator pump on the weber hitting the disty cap. but that shouldn't be too big of an issue that seems to happen on all of them. Link to comment Share on other sites More sharing options...
CIS Subaru Posted March 1, 2004 Share Posted March 1, 2004 Thanks. I'll have to take a look at this. Maybe I can work around it? (maybe put the manifold on backwards?) Link to comment Share on other sites More sharing options...
MilesFox Posted March 1, 2004 Share Posted March 1, 2004 what about mounting the disty backwards? take off the mounting flange and turn it upside down on the ea81. mount the disty body 180 backwards, but the rotor in time. then run the wires 180 to the cap, so they are in time with the rotor Link to comment Share on other sites More sharing options...
MiNoahsPinkMartini Posted March 1, 2004 Share Posted March 1, 2004 good luck! Yay new engine! Link to comment Share on other sites More sharing options...
CIS Subaru Posted March 1, 2004 Share Posted March 1, 2004 Miles, that sounds like a great solution if it works. Where would that leave the vac advance pointing? (sorry for stomping on your thread, Noah) Link to comment Share on other sites More sharing options...
MilesFox Posted March 1, 2004 Share Posted March 1, 2004 that is what i did when i mocked up the spfi intake to the ea81 block. the vac advance would point forward towards the front of the motor i also had ea81 in my 86 sedan, with ea82 intake. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 1, 2004 Author Share Posted March 1, 2004 It should be pretty easy to work around, its only the small coolant hose that gets in the way, if it was cut flush and pluged off then it wouldn't be a problem, but the issue would still remain about where to route the hose as it comes out from the block. Link to comment Share on other sites More sharing options...
MilesFox Posted March 2, 2004 Share Posted March 2, 2004 you may be able to connect the block's hose to the water pipe off the top of the water pump/block, using the ea82 manifold Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 2, 2004 Author Share Posted March 2, 2004 I'm down-grading this emergency from orange to yellow, there is only an elevated chance that this whole swap will blow up in my face again. Link to comment Share on other sites More sharing options...
