wrongturninwv Posted January 5, 2011 Share Posted January 5, 2011 (edited) 2001 Outback 3.0 VDC, check engine light on , code 171. What to look for and the cause. Anybody here had this problem and what did you do to fix it. Cleared code but came back on about 2 hours later. Also VDC off light comes and goes thanks Edited January 5, 2011 by wrongturninwv Link to comment Share on other sites More sharing options...
Legacy777 Posted January 5, 2011 Share Posted January 5, 2011 Here's some more info on the code, and some possible causes. http://www.obd-codes.com/p0171 Link to comment Share on other sites More sharing options...
wrongturninwv Posted January 5, 2011 Author Share Posted January 5, 2011 Thanks for the info, now I know what to start looking for. Ran some injector cleaner in a full tank of gas and light is off for now. Link to comment Share on other sites More sharing options...
wrongturninwv Posted January 6, 2011 Author Share Posted January 6, 2011 Ran just fine and light went out without having to reset. Best $2.87 I ever spent on Gumout highmileage fuel injector cleaner. Power came back just like it ran when I first bought it. Link to comment Share on other sites More sharing options...
Legacy777 Posted January 6, 2011 Share Posted January 6, 2011 Good to hear it sounds like it's fixed. Link to comment Share on other sites More sharing options...
rverdoold Posted May 31, 2014 Share Posted May 31, 2014 Ok giving this thread a bump up! I was driving with my propane converted 2009 outback 2.5 when it was giving a hissing sound, like leaking gas under pressure. It was like oops! yes the consumption of propane seems bit higher then before. After getting propane it did not switch to bi-fuel and remained driving on gasoline. Then CEL + VDC + cruise and a code PO171 bank 1 lean. The hissing sound had to be a leak, luckily it was a vacuum leak of the propane controller. I could fix it quickly and the car seems to run fine now. (I used freeSSM and a VAGcom OBD cable to read the codes) Link to comment Share on other sites More sharing options...
