Torsion Tubes 4wd vs 2wd?
I have finally located everything for my 4wd/MT swap.
Are the torsion tubes the same, or interchangable, between both models?
Thanks!
I some how posted this in the wrong place...can this be moved or deleted?
Edited by aaronxs400
I don't believe the 2wd version would have the diff mount bracket....
This is the physical difference between the 2. If you had only a 2wd oart available, you can fab a diff mount easily enough, at least if you knew what was supposed to be there or had one to compare to.
