HATCHY Posted January 11, 2011 Share Posted January 11, 2011 I was driving and everything was good. Them the car started gagging. And jumping. Then shutting down. Start up no problem. Umderload loses all power and hiccups dies. Then starts no problem isthia fuel filter Quote Link to comment Share on other sites More sharing options...
HATCHY Posted January 11, 2011 Author Share Posted January 11, 2011 i just fixed the fuel filter lucky i vroke down a block from oreillys. it seemed to fix the problem but on the way hom,e it sputtered one more time and then didnt do it again, what is going in Quote Link to comment Share on other sites More sharing options...
Subruise Posted January 11, 2011 Share Posted January 11, 2011 my 86 was doing that, thought it was the carb. it was the FF. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 11, 2011 Share Posted January 11, 2011 Did you replace both filters? GD Quote Link to comment Share on other sites More sharing options...
edrach Posted January 11, 2011 Share Posted January 11, 2011 I'm with GD on this one. The vapor "separator" in the engine compartment is not really a fuel filter. The fuel filter you need to replace is down by the fuel pump (underneath the car near the rear wheel on my Brat....not sure where it is on your car). Replace that first, before you look for more complicated reasons for the symptoms. Quote Link to comment Share on other sites More sharing options...
HATCHY Posted January 11, 2011 Author Share Posted January 11, 2011 (edited) so this morning the car worked and operated perfect. then about 20 mins into the trip same thing happened again. sputtering and dieing, could this be the crapy gas i put in from arco., maybe a bad batch of gas?? I cnt think of anything else it could be. im draining the tank today and changing the other fuel flter on the tank Edited January 11, 2011 by HATCHY Quote Link to comment Share on other sites More sharing options...
edrach Posted January 11, 2011 Share Posted January 11, 2011 so this morning the car worked and operated perfect. then about 20 mins into the trip same thing happened again. sputtering and dieing, could this be the crapy gas i put in from arco., maybe a bad batch of gas?? I cnt think of anything else it could be. im draining the tank today and changing the other fuel flter on the tank Those are the typical symptoms of an old fuel filter. For some reason it's aggravated in very cold weather. It probably won't go away until you replace the ff, but it couldn't hurt to pour a can of "dry gas" into the tank with the next fuel fillup. I don't see much benefit from draining the fuel tank; I'll leave that up to others since I've never had to do that even on my '82 or '84 Brats. Quote Link to comment Share on other sites More sharing options...
HATCHY Posted January 11, 2011 Author Share Posted January 11, 2011 So I took the wires off and found one wire to be rusted and corroded. At shucks there Not showing any other fuel filter. Bit the one under the Hood. Could this bad wire. Cause this to happen. Quote Link to comment Share on other sites More sharing options...
naru Posted January 11, 2011 Share Posted January 11, 2011 Maybe EA-81s have a second filter under the car.Make sure to change it. Apparently Shucks are idiots. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 11, 2011 Share Posted January 11, 2011 You need to go somewhere other than Shucks. That is not a good choice for Subaru parts. Napa is about the best of the "chain" stores and that's not saying much - they pretty much suck also. You can check for the proper parts listing through their web site though and then take in the part number to eliminate the counter-monkey from screwing up your order. If you have any specialty import parts houses around - go there. I use a place called Discount Import Parts - they started out as a VW parts house but from there branced into Audi and then all the rest of the import brands. They have the best prices and the highest quality parts - brands that no chain stores sell. It sounds like your issue might be that plug wire - but you should change that fuel filter anyway. It's easy and cheap. GD Quote Link to comment Share on other sites More sharing options...
HATCHY Posted January 11, 2011 Author Share Posted January 11, 2011 Appreciate the help. I usually use Napa. Thats where my clutch was from. So I just did front fuel filter and I'm about to do the rear. Full tune up cap rotor spark plugs (ngk) wires. And a bottle of heet. For the tank. I hope this it. Working on cara outside in the mud in he winter is rough Quote Link to comment Share on other sites More sharing options...
