impoutback 97 Posted January 11, 2011 Share Posted January 11, 2011 (edited) This thought just crossed my mind while gathering parts for my ej22 to ea82 dual range swap. I can't see how the starter still reaches the flywheel after loosing 1/4" of reach by adding the 1/4" adapter plate. U:banghead:nless the ej block pushes it closer by design/coincidence. This is what happens when you work on your car in the back of your mind:D Is it just plug and play? Edited January 11, 2011 by impoutback 97 Quote Link to comment Share on other sites More sharing options...
Numbchux Posted January 11, 2011 Share Posted January 11, 2011 bellhousing depth is less on the EJ engine than the EA82. So the thickness of the adapter plate is necessary to keep the flywheel the same distance from the input shaft, and therefore the starter as well. so yes, it'll work just fine. Quote Link to comment Share on other sites More sharing options...
impoutback 97 Posted January 11, 2011 Author Share Posted January 11, 2011 thanks Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 11, 2011 Share Posted January 11, 2011 There's no difference. The adaptor plate is designed to put the tranny in the same location relative to the EA flywheel. Thus it works just fine. The EJ does push everything closer because they don't use stepped flywheel's on the EJ's. That was part of making them larger yet not longer. GD Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 11, 2011 Share Posted January 11, 2011 FYI: The adapter plate should be 1/2"........(12~13mm) not 1/4" Quote Link to comment Share on other sites More sharing options...
impoutback 97 Posted January 14, 2011 Author Share Posted January 14, 2011 1/2 inch! really? Quote Link to comment Share on other sites More sharing options...
