O5 legacy abs light on non working cruise control
there are 2 fuses for ABS, one is under the hood in the fuse box and one is behind the cover to the left of the steering wheel.
did you check both fuses?
An ABS fault on the 2005+ will disable your cruise as a safety function.
Once you fix ABS the cruise will work again,
