dustinsdad Posted January 13, 2011 Share Posted January 13, 2011 (edited) Have the motor out of my 84 brat on the table. Doin the SPFI change per the instruction by GD, also just doin a general overall cleaning and replacing gaskets etc. While looking at everything I decided to check the compression. and i got the 30 then 60 then 90 climbing compression on all 4 cylinders. In my book it says that equates to ring issues, I am hoping that someone here will tell me that having no oil and the fact that it has been siitting out cold and dry will some how affect this. It ran okay when I shut it down, but if I have to pursue further work I guess best to do it now. Just wondering if a more experienced member may have some other advice. PS wasn't burning any oil that i know of, sprak plugs were a little sooty but not black and oily. Edited January 13, 2011 by dustinsdad Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 13, 2011 Share Posted January 13, 2011 How are you spinning it to check the comp.? Compression readings will depend on rotation speed..... you can't effectively check it by cranking it over with a wrench. GD Link to comment Share on other sites More sharing options...
dustinsdad Posted January 13, 2011 Author Share Posted January 13, 2011 WOO HOOO! that is exactly what I am doing, thank god for experienced answers. I tell ya i have been looking over and over trying to see if I was doin somethin wrong, but i could come up with nuthin. It never occured to me that turning by hand with a wrench would be an issue. thanks again and I will keep you apprised of my progress, slow as it may be. Link to comment Share on other sites More sharing options...
hatchsub Posted January 13, 2011 Share Posted January 13, 2011 Take all 4 plugs out of the motor as well. I made the mistake of doing one at a time and you wont get the same reading. Do that..hook up your gauge..then try turning it over (coil unplugged!). Link to comment Share on other sites More sharing options...
