TheLoyale Posted March 20, 2011 Share Posted March 20, 2011 I'm not sure how the Tophat would work with that kit, I know there are tons of threads on here about the whole Accord/Tempo spring swap. I'll do some searching and see what I find, and post it back here. Hmm.....sounds like something to look for at PAP.I'm assuming that an Accord coilover kit would work as well, somthing like this. If anything the ride height in the back is okay right now, but the load capacity is not. the accord springs would probably be okay though, as I doubt the back would be any higher than the front is now. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted March 20, 2011 Share Posted March 20, 2011 Well that took very little searching. Here are some other replys for you. http://www.ultimatesubaru.org/forum/showthread.php?t=114663&highlight=Accord+springs Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted March 20, 2011 Author Share Posted March 20, 2011 Darn, you beat me to the search! Oh well, I'll get better at it eventually. Thanks, that thread looks promising! Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted June 20, 2011 Author Share Posted June 20, 2011 The car now needs a water pump. Is there anything special that needs to be done to burp the system, or just leave the radiator cap off and warm it up? Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 20, 2011 Share Posted June 20, 2011 The car now needs a water pump. Is there anything special that needs to be done to burp the system, or just leave the radiator cap off and warm it up? Thats about it, it will take forever for the thermostate to open if it just idles. Hold it up to 3000rpm off and on to warm it up quicker. Quote Link to comment Share on other sites More sharing options...
bigjimd Posted June 21, 2011 Share Posted June 21, 2011 I have one of the radio adapters here you can have for $5.00 plus shipping if you want it. I think that's what I paid for it at the upulit. It's deeper so the longer style radidios will fit. Quote Link to comment Share on other sites More sharing options...
heartless Posted June 21, 2011 Share Posted June 21, 2011 The car now needs a water pump. Is there anything special that needs to be done to burp the system, or just leave the radiator cap off and warm it up? raise the front end up a little - they can be a little stubborn to burp all the air out sometimes. lifting the front will help that. then, once you think you have it - fill the overflow to the correct level, and check it regularly for a while to make sure it stays up. oh - BTW - not sure if you ever got an answer on the towing thing - but yeah, 5 spd FWD car should be fine - it is the AWD ones that have issues. Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted July 8, 2011 Author Share Posted July 8, 2011 The Loyale is up and running again! I ended up having to take the drivers side timing belt tensioner off just to see what I was doing as I scraped the old gasket off! And of course the timing belt covers did NOT go back on. Hello. Congrats on your new Roo. I have basically the same car just a year older. I was posting about your CEL. I have had mine throw a couple codes and the CEL stayed on solid. The only time that I saw it blink was when the test connectors above the brake booster by the fuel filter were plugged together. There are two White connectors with one wire and two Green connector with one wire. Neither one of them should be hooked together unless you are running diagnostics. Thought I would throw it out there. Maybe it'll help. Hope you are as happy with yours as I am with mine. Good Day to you. Don Yep, it was the test connectors. I have one of the radio adapters here you can have for $5.00 plus shipping if you want it. I think that's what I paid for it at the upulit. It's deeper so the longer style radidios will fit. Thanks, but we sourced a stock radio at PAP. It also got two nicer front seats, and a new rear seatback, also courtesty of PAP. One of the next things is a front axle. What are the good non-oem axles? Several local parts stores have axles with a lifetime guarantee in the $50-70 range. Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted July 27, 2011 Author Share Posted July 27, 2011 I'm putting in a new clutch cable and can't quite figure out how to do it. What's the trick to getting the pin out of the clutch pedal? I can't see it, and can't feel anything, does it have a cotter pin or snap ring or something else? Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted July 29, 2011 Author Share Posted July 29, 2011 Bump, I still haven't figured it out. I'm sure it's something simple, I just haven't found it yet. Quote Link to comment Share on other sites More sharing options...
bigjimd Posted July 30, 2011 Share Posted July 30, 2011 Here's a couple of pics I just took for you. I haven't put this in the car yet so it was easy. It looks like the kind of clip you have to pry off with a small screwdriver. Like the kind of thing that holds the wheels on toys. I would think it would be easier to unbolt the cable first. Good luck sure looks easier sittin on the trash can than in the car. Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted July 30, 2011 Author Share Posted July 30, 2011 Here's a couple of pics I just took for you. I haven't put this in the car yet so it was easy. It looks like the kind of clip you have to pry off with a small screwdriver. Like the kind of thing that holds the wheels on toys. I would think it would be easier to unbolt the cable first. Good luck sure looks easier sittin on the trash can than in the car. Hmm...that does look difficult. Ours didn't have that clip at all, just a slight press fit through the pedal. I'm not even sure how I'd put that back on with a clip anyway, it was challenging without. Thank you for the picture, that's just what I needed! Quote Link to comment Share on other sites More sharing options...
bigjimd Posted July 30, 2011 Share Posted July 30, 2011 Hmm...that does look difficult. Ours didn't have that clip at all, just a slight press fit through the pedal. I'm not even sure how I'd put that back on with a clip anyway, it was challenging without. Thank you for the picture, that's just what I needed! Glad to help I thought the pic would make it easier. I have no idea what year that assembley is from other than being a Loyale wagon at the upulit. I do know that the darker pic is from an 86 XT as it came with the tranny we bought and they both had that little clip on em. The pin posistion is different on both of them. The outside picture one looks to me like it should be flipped around as it rubs on the housing. Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted August 7, 2011 Author Share Posted August 7, 2011 The water pump I just replaced started leaking yesterday. I thought it was probably the base gasket or the o-ring; I checked it out today and it wasn't. It's hard to see in this pic, but the water seems to becoming out of the little weephole directly opposite the heater hose fitting. What would cause this? Can I just plug it? Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted August 8, 2011 Share Posted August 8, 2011 Sounds like a crap remanufacture to me. I'd take it back for refund/exchange. Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted August 17, 2011 Author Share Posted August 17, 2011 Sounds like a crap remanufacture to me. I'd take it back for refund/exchange. Yep, after only 350 miles the impeller side had a 1/4 inch of play in every direction. The replacement was NOT a reman, but a new one. In other news, the car got some fresh new tires recently. Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted June 18, 2013 Author Share Posted June 18, 2013 After a couple years of mostly just driving the car, The motor is now out for a re-seal. I have an entire seal/gasket kit, what should I re-seal and what should I not bother with? Quote Link to comment Share on other sites More sharing options...
jj421 Posted June 18, 2013 Share Posted June 18, 2013 Wow, quite the bump, haha. Hah, I just had problems with my water pump. Crappy aftermarket one. Put an OEM one back on and fixed the problem Now, I can't help you with the seals/gaskets, but what tires are you running in that picture? I can see "Mohawk" on it, but what size/model tires are those? That is, if you still have them/can remember. I'm liking the tread pattern. Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted June 18, 2013 Share Posted June 18, 2013 Holy late to the ballgame...........What tires are those, what specs, and where'd you get them?? Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted June 20, 2013 Author Share Posted June 20, 2013 (edited) I think they were Mohawk Sno-Belt Radials, I believe 165/60-13. It would seem that they were cheap because they are no longer made, one of them gave up within a few months. The other is now the spare. Edited June 20, 2013 by soobenthusiast Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted June 20, 2013 Share Posted June 20, 2013 Dammit. Guess I'm still stuck with Winter iPikes Quote Link to comment Share on other sites More sharing options...
l75eya Posted June 21, 2013 Share Posted June 21, 2013 (edited) wow, There is a crap-ton of stuff happening to this car all at once lol!What kinda tyres are those? They look like agriculture type tyres.*edit* whoops. Maybe I should read everything first. Kinda like Apple end user agreement, skip, skip, skip agree. =P Edited June 21, 2013 by l75eya Quote Link to comment Share on other sites More sharing options...
