Computer
Hello all. Need any help/insight you might have. The short story is....my 85 BRAT 1800 is a California car. The other night when I turned it off it would not stop running. The ignition checks out and I believe its the computer. It is flashing at me. I was told to "re-boot" it by disconecting the battery. No help. NAPA has a reman computer and thats where I am leaning. Any other suggestions? Thanx, Subarat
It eventually died, or it stumbled, or it just plain kept running perfectly?
I highly doubt its the computer unless its a Turbo EFI model but even then. If its carb'd the computer has nothing to do with it running or not just how it runs.
I would lean to the ignition/fuel pump relays if its the 3rd option but I haven't ever heard of a Brat doing that. Is it a Turbo? All the turbos are 83/84 but some people misread the build date and its possible a couple got carried over to 85 year I suppose but its unlikely.
Probably not the computer - the engine will run with that completely disconnected and thrown in the trash (just for example) and will still shut off, etc. The EA81 feedback ECU's don't even control the fuel pump.
Sounds like you have a short that's powering the ignition coil without the switch being in the on posistion. Could be the ignition switch itself even.
It is probably not the switch. It is more than likely the pink connection under the steering column. The hot lead over-heats for some reason. You may have to replace the connectors or just seperate the affected wires and add new connections for them seperate of the harness.
Good luck
My first thoughts on the trouble were stuck relays or bad ignition switch also as others here have stated already. If there are no ignition relays and the ignition switch has been replaced already then there must be a bridged path to power on the ignition circuit somehow. Check for power on the + coil lead while the ignition is OFF. If power is found there then start removing fuses in a effort to find which circuit is providing the power. As a wild guess try removing the rear connector on the alternator to see if that helps. If it does kill the path to power then replace the alternator. To see if the ECU is providing the path somehow disconnect it while monitoring the voltage at the coil.
Edited by Cougar
+1. I have seen this before. The connection is poor and will melt the plastic eventually leading to a short - in your case the short may be bypassing the switch for the ignition power.
I would sugest ording a new ignition switch from the dealer ($35) as they get pretty worn out by this vintage usually. That will give you new connections on the switch side - then you can either solder in a good body side connector or clean it up as best you can and replace those pins that you can't save with crimp-on spade terminals.
