AL1 Posted March 1, 2004 Share Posted March 1, 2004 Hi there, first post on the board (beer ) question mostly for euro readers as LPG seems very marginal on the other side of the pound: is LPG with the 2.5L 2000' engine a good idea ? any issues with that setup ? What sort of milleage can I expect without major problems arise ? bottom line is i'm thinking of getting a used Outback and most of them come with LPG in France. (with petrol at 1 euro/litre don't ask why ) thanks for input ! AL1 Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 2, 2004 Share Posted March 2, 2004 You'll loose about 15-20% power with the CNG, but its a great idea, i don't know about your refueling structure over there in france, but over here it would only work in the big cities. because its a gas, not a liquid the engine burns a lot cleaner and unlike petrol there won't be any condensation on the cylinder walls so it should last longer, longer than 300,000 isn't bad!! If its already done from the factory i can't see any reason not to, but if you plan a conversion it may be a little bit tricky, but still may be worth doing. Bonjour and welcome to the board Link to comment Share on other sites More sharing options...
AL1 Posted March 2, 2004 Author Share Posted March 2, 2004 thanks dude :-) I heard there could be some issues with the valves seats (don't know how to call that in english, i mean the part of the gazket on top of the cylinder where the valve close the cylinder ?) i understand the gazket is not strong part of the engine, so... Link to comment Share on other sites More sharing options...
Tolerance02 Posted March 2, 2004 Share Posted March 2, 2004 I have no experiance with 2.5 engines but all other Subaru engines are well known as perfect convertible to LPG. Since You live in Lille, it's not far away from the Belgian border. I'm not sure about the French-speaking side but in Flanders and Holland are many shops who are specialised in LPG convertion. There is no longer power loss with the latest developements of LPG injection. As we say here: 'it runs like a sewing machien'. But the whole installation became pretty expencive, about 2500 Euro all included. There are cheaper systems but than You have powerloss and more technical problems. I will e-mail some adresses if You will. Tolerance-1@skynet.be. Urban. Link to comment Share on other sites More sharing options...
AL1 Posted March 2, 2004 Author Share Posted March 2, 2004 Originally posted by Tolerance02 I have no experiance with 2.5 engines but all other Subaru engines are well known as perfect convertible to LPG. ... There is no longer power loss with the latest developements of LPG injection. As we say here: 'it runs like a sewing machien'. ... There are cheaper systems but than You have powerloss and more technical problems. I understand Subaru Belgium has some factory conversions available as well, probabely the same as the one sold in by subaru France ? Do you have any info wether that system is of the latest generation you're talking about ? My point is that 90% of the used outbacks i could find on the french market have the factory LPG conversion kit: that's the one I investigating on ;-) Thanks for input, and check your emails ! just to answer to another question regarding the LPG distribution network: yes it's quite easy to find LPG anywhere in france but I reckon you'll have to use standard fuel once in a while specialy in remote country side or mountain. No problem arround big cities or along major roads... Link to comment Share on other sites More sharing options...
Sweden Posted March 2, 2004 Share Posted March 2, 2004 Not to jump off the subject too much here, but can I assume that the LPG systems will also burn biogas (in the purified form for vehicle use) just as well? Sweden Link to comment Share on other sites More sharing options...
