Sioux-baru Posted January 15, 2011 Share Posted January 15, 2011 yesturday after class, I was on my way home and not more than a block away from college, going into 2nd as the clutch pedal went down, I heard a snap and the pedal hit the floor. So there I am, thinking what the H*** just happened??. I have momentum and get the car into the nearest parking lot and start looking under the dash and hood. didnt get a good look at it, those little key lights dont give enough light. but feeling around, the cable slides back and forth under the dash at the top of the pedal. Sitting there thinking whether if I should push or tow it home and as I shift in/out of gear( the engine is off) realizing that I can start this thing in 1st gear and get going and creep home in 1st. one problem- there is 10 lights and 2 stops(rolled thru both) signs to get this car home. (this is the least number of lights and stops signs route of 5 miles) shifting up is easy, its coming down thats hard. You know your a subie owner if: you can shift through all the gears without grinding gears and no clutch. Theres another thread for that in here somewhere. I didnt make it through light #4. bump start again. I know its hard on the starter, but it has a warranty. I ordered a new cable from my fav parts store, the clerk is getting to know me, I just mention "subaru", that will be here tomorrow. Q: is it difficult to install a cable? Quote Link to comment Share on other sites More sharing options...
jonlittleford Posted January 15, 2011 Share Posted January 15, 2011 not too difficult, from what I remember. (EA-81) Just get hill holder out of the way, unthread the nut, detach there and above the pedal... of course this was five years ago. But the fact that I was able to do it at all means "not too difficult." Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 15, 2011 Share Posted January 15, 2011 You should get the OEM cable from the dealer - aftermarket is inferior. You can drive without a cable - rev match your shifts and start the engine in first. Yes it will die at stops. Yes it is frustrating. Yes it can be done and yes I've done it for way too many miles. Follow my guide to replace the cable: http://home.comcast.net/~trilinear/clutch.html GD Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 15, 2011 Share Posted January 15, 2011 drive with no clutch. start car in gear, shift by matching rpm, throw in neutral when stopping and turn off car. Repeat Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted January 15, 2011 Share Posted January 15, 2011 since the ea81 clutch cable direct from subaru is only 12.95, why put something aftermarket on it (as said they are inferior when bought aftermarket). Quote Link to comment Share on other sites More sharing options...
Delta Brat Posted January 15, 2011 Share Posted January 15, 2011 Many times I have found that if you don't lube on (I use marine grease but any good quality grease works well) the place where the throw out bearing slides back and fourth on.... the amount of force required to push the pedal down is tremendously increased. I have seen firewalls torn up, clutch cables worn out, clutch cables snapped, and pedal assembly's broken. Not to mention all kinds of hydraulic problems with hydraulic systems. Many poor repair shops forget to lube this spot any many customers complain of hard clutch pedal. Shops usually shrug this off and tell the customers that it's a higher duty clutch. The auto repair world is full of dishonest individuals. But that is a topic for other discussions. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 15, 2011 Share Posted January 15, 2011 ... The auto repair world is full of dishonest individuals. ... ...Specially if the Costumer knows Nothing about Basic Mechanics nor Maintenance. Quote Link to comment Share on other sites More sharing options...
Indrid cold Posted January 15, 2011 Share Posted January 15, 2011 +1 for Subaru clutch cable... you will be sorry for getting the other as it will only last a year or two... my experience. Quote Link to comment Share on other sites More sharing options...
