Remove bolt from rear lateral link
Got a used suspension from a yard. The monkey that pulled the parts cut the rear lateral link off the crossmember with a torch, because he couldn't get the bolt out.
Any suggestions for getting that bolt out of the frame side of the rear lateral link?
firsthand experience, don't buy the lateral link if the bolt is seized in it, go get another that the bolt comes out of. A yard sold my brother the entire crossmember so he could get his lateral links and we simply could not get them out of the crossmember it was seized at the inner bolt, poundeing, heating etc it was seized in the bushing. We took it back and found one car out of 5 at a yard that we could get the bolts out of. Luckily, on my bros car, the bolts came out fine.
when you put it back together apply antisieze.
so how do you get them out of the crossmember already installed in the car?
Changing the crossmember is not an option, the bolts for the diff are too rusted.
Could they be cut out with a sawzall?
