90 Loyale stuck in 4wd
Loyale90
Push button 4wd? Theres a little mechanism on the side of the tranny that unlocks the rear from 4wd. Try moving that manually from underneath.
I believe its a vac operated gauge from the button, so theres something screwy in your electrics or vac lines preventing that mechanism from disengaging probably. When i flat towed my Subie I had to crawl under and check that thing was off before i started towing it.
