Tonyp5143 Posted January 18, 2011 Share Posted January 18, 2011 A local Subaru mechanic told me to be sure and check the front diff for proper fluid level. He said that excessive heat from the exhaust constantly bakes the diff seals and causes them to leak. And if left unchecked fluid level will be really low, and I could lose the front diff. Well, the fluid level was barely on the stick. I refilled the fluid to the proper level, and when I drove the Brat, fluid POURED from the diff seals. I drained the diff and refilled with straight Lucas and the leak stopped for now. So I guess I am gonna be replacing the front diff seals soon, but in searching the website, that sounds like a risky job, due to obtaining proper clearance. What would you guys do? Thanks, Tony P Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 18, 2011 Share Posted January 18, 2011 yeah replace the seals. sounds like you're already on it and found some info. follow the directions posted here. do one at a time and count the number of turns and reinstall the retainers exactly the same number of turns and the same spot - this retains the clearance. set up properly, give yourself time, work slow and you should be good. i'd get that lucas out of there and get some diff fluid in a.s.a.p. just my personal preference. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 18, 2011 Share Posted January 18, 2011 Punch mark both the ring and the case to indicate the current setting. Count the number of turns as you remove and when the threads get close to letting go apply outward pressure and make a seccond punch mark on the case indicating the proper location to re-engage the threads. It's pretty straightforward. GD Quote Link to comment Share on other sites More sharing options...
