murphywd Posted January 18, 2011 Share Posted January 18, 2011 Trying to fix my sister's BF's car with absolutely NO budget... 1997 Legacy with a 2.2L motor. Car ran rough intermittently, then bogged down at idle while in gear, then just died. He's replaced fuel filter, coil pack, and we just put in another ignitor with no change. We get spark to 3 & 4, but not 1 & 2. We've traced wiring from the ignitor to the coil and it's good, but we can't seem to figure out which pin from the ECU goes out to the ignitor. (well at least we couldn't figure it out yesterday before my back forced me to quit) Any suggestions what this gremlin could be? Link to comment Share on other sites More sharing options...
heartless Posted January 18, 2011 Share Posted January 18, 2011 just out of curiosity (and to eliminate a possibility) have you tried swapping the plug wires around? (ie: pull 3 or 4 and try on 1 or 2) might be odd, but it is possible the plug wires are bad if there is power going to the coil pack, but not producing spark at the spark plug? Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 18, 2011 Share Posted January 18, 2011 Will it start at all now? Is the "new" coil pack brand new or used? Link to comment Share on other sites More sharing options...
murphywd Posted January 18, 2011 Author Share Posted January 18, 2011 Coil is brand new from parts store. Link to comment Share on other sites More sharing options...
murphywd Posted January 18, 2011 Author Share Posted January 18, 2011 What I don't get is that everything I could find pointed to a bad ignitor. We swapped that out and nothing. He's replaced a whole lotta stuff, but no one can afford to just keep throwing parts at it. We're trying to eliminate the possibility that it's a bad wire to the ignitor from the ECU, but can't find a decent diagram or pinout chart (that shows which pin on the plug is which) It seems as if the ECU is sending a signal to fire one pair of cylinders, but not the other. I don't have a manual, so I don't know if the ECU triggers the ignition off the crank or the cam position sensor. If it's one of these 2, how do we go about checking it with a test light and digital multi-meter as the only electronic diagnostic tools available? Every time I think about it I want a LARGE beer! Link to comment Share on other sites More sharing options...
subaruguru Posted January 18, 2011 Share Posted January 18, 2011 (edited) The crank angle sensor runs the spark the cam sensor runs the fuel i agree with heartless check the plug wires i know its a stupid simple fix but about a month ago my friends impreza was missing on 1 and 3 tried everything then put plug wires from a junk motor on it and it ran great. My second guess is something that happend to me is one of the tabs on the crank sprocket for the spark got busted off i assume a rock got thrown up into it (no covers). hope that helps Rob. Edited January 18, 2011 by subaruguru Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 18, 2011 Share Posted January 18, 2011 Check for proper power to the coil - there are two sides to the coil so there are two leads that have to be powered going into the coil pack. I'm pretty sure that's how it works. They might be powered off seperate fuses..... Did you try a third ignitor? I've seen them fail where only half the coil would fire. GD Link to comment Share on other sites More sharing options...
ocei77 Posted January 18, 2011 Share Posted January 18, 2011 (edited) Trying to add pdf's for igniter etc. System tells me invalid file. pm me e mail and I'll send them that way. O. Edited January 18, 2011 by ocei77 add Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 18, 2011 Share Posted January 18, 2011 FSM pinout for the Coil has only 3 wires. One (yellow) is power with ignition run/start. The other two (Red w/green, Blue) go to the ignitor module through connector B22. It's a large grey 16 pin connector on the passenger side top o the bellhousing. Check those for continuity. Visually check the wiring for cuts/cracks in the insulation. Also check all the connectors (especially B22) for corrosion/dirt in the pins. Spray them with some contact cleaner to ensure cleanliness. Sometimes unplugging and plugging them back together a few times get's them cleaned up. The Crank and Cam angle sensors can only be checked with an analog multimeter or Oscope. Doubtful it's either of those since the ECU would not see the signal it wants from those sensors. I would think it would not fire at all if that were the case. 1 Link to comment Share on other sites More sharing options...
bheinen74 Posted January 18, 2011 Share Posted January 18, 2011 timing a tooth off perhaps on a cam? Link to comment Share on other sites More sharing options...
Cougar Posted January 20, 2011 Share Posted January 20, 2011 (edited) I think Subaruguru has the problem pinned down. I thought of the same thing myself when I read the post. When this kind of trouble happens the reluctor tabs for the crank sensor need to be checked. There are two sets of tabs and they each control a pair of sparkplugs. The firing is controlled through the ECU. Here is a link that shows some good shots of the engine. Check out the 34th picture. It shows good detail of the reluctor tabs behind the crank sprocket and the crank sensor above it. http://lovehorsepower.com/joomla/index.php?option=com_content&view=article&id=48:1995-subaru-legacy-outback-timing-belt-and-water-pump-replacement&catid=10:subaru-legacy&Itemid=64 Edited January 20, 2011 by Cougar Link to comment Share on other sites More sharing options...
