opus Posted January 19, 2011 Share Posted January 19, 2011 How do you get around ripping your door gaskets off everytime it freezes. The little plastic things are totally worthless, they just rip the rubber. Screw them into the door?? Link to comment Share on other sites More sharing options...
bheinen74 Posted January 19, 2011 Share Posted January 19, 2011 the newer ones are even worse than the old ones. 2 steps backward in the engineering of them for a cold climate. Screws may hold the door rubbers, sure dont work the way the engineers did it. Link to comment Share on other sites More sharing options...
moosens Posted January 19, 2011 Share Posted January 19, 2011 Silicon spray - won't stick , doesn't hurt the rubber. Link to comment Share on other sites More sharing options...
opus Posted January 19, 2011 Author Share Posted January 19, 2011 moosens said: Silicon spray - won't stick , doesn't hurt the rubber. Nope, done that. Only works once or twice. Wouldnt matter now anyway, they are all ripped. Link to comment Share on other sites More sharing options...
bheinen74 Posted January 19, 2011 Share Posted January 19, 2011 lots of other cars actually use more than a toothpick type clip to hold the rubbers into the door. - Subaru needs to design these better. Wax the door jambs so they are smooth. Applying silicone and conditioner does help, but the whole design is partly to blame, of those ridiculously small and flimsy poorly designed clips. Link to comment Share on other sites More sharing options...
Rust Posted January 20, 2011 Share Posted January 20, 2011 liquid nails worked for me. Link to comment Share on other sites More sharing options...
1982gl4 Posted January 20, 2011 Share Posted January 20, 2011 After mine all fell off I drilled new holes into the gasket and moved it over a little bit. It appears to be holding up pretty well! In my other car I used WD-40 on the gaskets and that seems to be working okay. I think waxing the jams is a good way to go as well. Link to comment Share on other sites More sharing options...
MilesFox Posted January 20, 2011 Share Posted January 20, 2011 3m super weatherstrip adhesive works to glue it back down with its original clips. Clean the surfaces well. Try syl-glide(brake caliper grease) if the spray is not heavy duty enough. The product lists several uses beyond brakes, and one suggestion is trunk lid seals. Link to comment Share on other sites More sharing options...
TomRhere Posted January 20, 2011 Share Posted January 20, 2011 Cooking spray also keeps the seals from freezing to the door(s). Link to comment Share on other sites More sharing options...
