Scott in Bellingham Posted January 20, 2011 Share Posted January 20, 2011 is the engine bolt pattern the same on the 2.2. and the 2.5 ? Link to comment Share on other sites More sharing options...
idosubaru Posted January 20, 2011 Share Posted January 20, 2011 (edited) yes. or more correctly: yes and no...or sort of no. all EJ's and EG33 are the same prior to 1998. the bellhousing bolt patterned changed in 98 (or 99, pretty sure it's 98 though), but even still you can bolt an old engine up to the new style bellhousing just fine, just different number of bolts (4 and 8). for swapping engines and trans it doesn't matter that it changed. Edited January 20, 2011 by grossgary Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 20, 2011 Author Share Posted January 20, 2011 grossgary said: yes. or more correctly: yes and no...or sort of no. all EJ's and EG33 are the same prior to 1998. the bellhousing bolt patterned changed in 98 (or 99, pretty sure it's 98 though), but even still you can bolt an old engine up to the new style bellhousing just fine, just different number of bolts (4 and 8). for swapping engines and trans it doesn't matter that it changed. thanks so a guy with a 2.5 can use my EJ adapter and bolt up a EA82 Dualrange, nother Question are the bolt pattern on the flywheels the same? Link to comment Share on other sites More sharing options...
idosubaru Posted January 20, 2011 Share Posted January 20, 2011 flexplates have to be swapped when doing an EJ22/EJ25 swap, flywheel...escaping me at the moment. Link to comment Share on other sites More sharing options...
Qman Posted January 20, 2011 Share Posted January 20, 2011 Scott in Bellingham said: thanks so a guy with a 2.5 can use my EJ adapter and bolt up a EA82 Dualrange, nother Question are the bolt pattern on the flywheels the same? Yeah Scott, they can use it. And yes, the EJ "flywheel" bolt pattern is the same. Link to comment Share on other sites More sharing options...
renob123 Posted January 20, 2011 Share Posted January 20, 2011 Scott in Bellingham said: thanks so a guy with a 2.5 can use my EJ adapter and bolt up a EA82 Dualrange, nother Question are the bolt pattern on the flywheels the same? I have an EJ25 block in my Brat. It has your redrilled flywheel and adapter plate hooked up to a 5-speed D/R. That should answer your questions. Jacob Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 20, 2011 Author Share Posted January 20, 2011 renob123 said: I have an EJ25 block in my Brat. It has your redrilled flywheel and adapter plate hooked up to a 5-speed D/R. That should answer your questions. Jacob I shoulod of known thanks dude Link to comment Share on other sites More sharing options...
