baja Posted January 24, 2011 Share Posted January 24, 2011 hi im tring to fix a friends legacy wagon its an auto and wont start it doesnt crank or anything i know one problem is the battery is crap but i hooked jumper cables up to my car with it running and the car turns on and the trans temp light ,check engine light, and the oil light ,stay on and when i try to cranking it ,it just clicks once i checked the started but it is fine and i thought maybe the sensor for the park was bad but it works fine so i just wondering what else i should check thnx Link to comment Share on other sites More sharing options...
Legback Posted January 24, 2011 Share Posted January 24, 2011 Battery is SOOO dead it won't even take a jump. New battery first. then go from there. Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 24, 2011 Share Posted January 24, 2011 (edited) X2 on battery How did you check the starter? The contacts in these starters wear out and often cause problems like this. Edited January 24, 2011 by Fairtax4me Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 24, 2011 Share Posted January 24, 2011 Damn double posts.... Link to comment Share on other sites More sharing options...
naru Posted January 24, 2011 Share Posted January 24, 2011 +3 Jump it w/original battery disconnected. Link to comment Share on other sites More sharing options...
Legback Posted January 24, 2011 Share Posted January 24, 2011 If you're on the edge about the battery..have it tested with a good old analog tester(if you can find one). That new fangled Interstate battery computer lies. It had me replace my perfectly good original Denso starter with an inferior napa slow reving remanned crap....what a tragedy. Dig the old analog battery tester out of the drawer just in case the fancy one isn't feeling well. Link to comment Share on other sites More sharing options...
baja Posted January 24, 2011 Author Share Posted January 24, 2011 so definatly battery thnx guys Link to comment Share on other sites More sharing options...
