one eye Posted January 24, 2011 Share Posted January 24, 2011 (edited) So I was checkin out CL a few days ago and found some new tires, they where a little big but I figured...... I will do it............... here is what it look like now 31x10.50x15 Super Swamper TSL's and a new set of wheels too............ Jeff Edited January 24, 2011 by one eye Link to comment Share on other sites More sharing options...
obk25xt Posted January 24, 2011 Share Posted January 24, 2011 You will be satisfied... Swampers are 2nd to none.... Link to comment Share on other sites More sharing options...
lesstutrey Posted January 24, 2011 Share Posted January 24, 2011 (edited) very nice.. but i'd be painting those wheels Jealous you can run 6 bolts period though. Edited January 24, 2011 by lesstutrey Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 24, 2011 Share Posted January 24, 2011 Awesome you wont regret it , 31s !!!!!! thats great :brow: Link to comment Share on other sites More sharing options...
mcbrat Posted January 24, 2011 Share Posted January 24, 2011 lesstutrey said: very nice.. but i'd be painting those wheels Jealous you can run 6 bolts period though. wheel color looks good to me.... Link to comment Share on other sites More sharing options...
curtisbad Posted January 24, 2011 Share Posted January 24, 2011 those look awesome! i bet they're fun to play with too. have you had them in any gooey mud yet? curtis Link to comment Share on other sites More sharing options...
88Subi4x4 Posted January 24, 2011 Share Posted January 24, 2011 SWAMPERS! looking awsome... cant wait to see thos things in action Link to comment Share on other sites More sharing options...
one eye Posted January 24, 2011 Author Share Posted January 24, 2011 I just got them on this afternoon, picked them up in White Center around 10am and had them on my car at about 3pm, I cant wait to use them, but I got a little work ahead of me before I can go wheeling again. This last Run was a bit hard on old Butters, I broke a couple of welds, tore a mirror off and smashed some of my pannels up. Not to mention I need to pound over the pinch welds and trim a little on the fenders, 30s would work with little cutting and pounding but the 31's with lots of tread, need some clearance............................ Jeff Link to comment Share on other sites More sharing options...
monstaru Posted January 24, 2011 Share Posted January 24, 2011 nioce......... Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 24, 2011 Share Posted January 24, 2011 one eye said: I need to pound over the pinch welds and trim a little on the fenders, 30s would work with little cutting and pounding but the 31's with lots of tread, need some clearance.. Jeff I have 31s on the front of the 5 door white wheeler , I extended the radius rod 1" helped a bunch, Link to comment Share on other sites More sharing options...
one eye Posted January 24, 2011 Author Share Posted January 24, 2011 Scott in Bellingham said: I have 31s on the front of the 5 door white wheeler , I extended the radius rod 1" helped a bunch, Ya Bill did that on his too, I think I might have to do it just to get it to turn and not tear the knobs off on the Tires.................... Jeff Link to comment Share on other sites More sharing options...
obk25xt Posted January 24, 2011 Share Posted January 24, 2011 Scott in Bellingham said: I extended the radius rod 1" helped a bunch, +1 Mine are extended 1.25" and it does help a lot. The sleeve over the radius rod helps beef things up too. Also I think it helps to create a little more caster and a little better approach angle too. After I sleeved them and was putting it all back together I put the outer bolt in first, then had to ream out the other hole in the control arm to get the bolt through. Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted January 24, 2011 Share Posted January 24, 2011 Looks good! With more traction and ground clearance, you can get in even MORE trouble! w00t Link to comment Share on other sites More sharing options...
brysawn Posted January 24, 2011 Share Posted January 24, 2011 Scott in Bellingham said: I extended the radius rod 1" helped a bunch, How do you go about doing this? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 24, 2011 Share Posted January 24, 2011 brysawn said: How do you go about doing this? cut radius rod in half slip pipe over and weld pipe to shaft Link to comment Share on other sites More sharing options...
