Gauge swap
Arty
I have a '95 OBW. I really like the newer gauges more, though, the ones with the orange markers and needles. I'm not 100% sure what year they come off of or if they'll even work at all. I know they also have a digital read out instead of analog. If I were to want to swap to the newer gauges, would it be possible?
Anything is possible. Might be more work than you want to do. Not sure if the '95 had a cable-drive speedo or electronic..... something to take a look at. For sure some of the connectors would be different. I'm sure with enough time and some schematics you could make it work. There isn't that much to a cluster.
Aside from taking the cluster out of the dash is there any way to tell?
And do you happen to know which years did have an electronic speedometer per chance?
I know the '96 Outback I'm working on right now has electronic. It's possible that your '95 does as well.
The connectors WILL be different. That I know for certain. There are differences between body styles as well as differences between years. I know the speedo head connector on a '96 is different from a '97 for example. Physically incompatible. So reqwireing using the donor car's harness connectors will be required for sure.
Big help, thanks. I suppose maybe just swapping the needles and or gauge faces would be the better way to go? I'm actually starting to wonder if any of it will fit without some sort of crazy retrofitting.
Ok, I figured out that the gauges I want are in fact from a '98. I've never messed with gauges before... if I were to just take the accent pieces off of the 98 cluster and put them on my 95 (such as the needles), what risk do I run of throwing off the calibration of my current gauges? E.g- gas level, speedo...
Any help is greatly appreciated.
:D I always have done something to my car :D
it's electronic
it's electronic
Awesome, thanks man.
Does this mean I won't have to worry about the gauges being wrong if I mess with them? That's what I'm incredibly worried about. That and the mileage being all kinds of wrong.
Bumping for this answer.
What exactly do you mean?
If you don't play with the mechanisms that control the movement of the gauges, or the mileage, it'll be fine. DON'T pull the needles off, it's a real big pain in the butt to get them to read correctly again.
