vic/se Posted February 3, 2011 Share Posted February 3, 2011 You sould open that bleeder bolt, to bring piston back, and then slide new brake pads. clean everything well don't over grease and don't grease everywhere....if you don't understand my point just look at a new car, and take you own conclusion good luck on you brake job Link to comment Share on other sites More sharing options...
Rooster2 Posted February 3, 2011 Share Posted February 3, 2011 vic/se said: You sould open that bleeder bolt, to bring piston back, and then slide new brake pads.clean everything well don't over grease and don't grease everywhere....if you don't understand my point just look at a new car, and take you own conclusion good luck on you brake job I disagree on opening the bleeder when retracting the caliper piston. That is unnecessary. Keep the bleeder closed when tracting the piston, will push the brake fluid back through the line to the m/c reservoir. The fluid level will rise slightly in the reservoir. If the reservoir is already filled to the max level, then remove the reservoir cap, and wrap a rag or paper towel around the reservoir to catch any over brake fluid flow. The bleeder should be opened only when you want to drain dirty brake fluid from the system, and replenish with new. Otherwise, you make work for yourself at pad changing by having to bleed air out of the line. Link to comment Share on other sites More sharing options...
rverdoold Posted February 4, 2011 Share Posted February 4, 2011 I forgot to mention to try and loosen the bleeder bolt before you remove the clamp from the car. It is easier when still mounted on the car. Just break it loose and tighten it a bit again. Link to comment Share on other sites More sharing options...
