horse66 Posted February 2, 2011 Share Posted February 2, 2011 hey guys just my first brat its an 84 needs body work but motor is great havea hard time getting in 4th gear any sugestions also need plenty of aprts any thing u can do to help would be great Link to comment Share on other sites More sharing options...
idosubaru Posted February 2, 2011 Share Posted February 2, 2011 post in the proper forum - "old generation" probably for a brat. a mod may move it sometimes to the proper forum. describe the issue in the title, "help" for a title doesn't help you or anyone else. there's an edit feature so you could actually update the title of your original post. as for the clutch, is it a hard time always getting it in 4th gear, will it go in to gear if you double clutch it? is the shifter sloppy? have you checked the fluid or changed it? a synthetic fluid might help smooth things out a bit. synchro's are probably sloppy? and for your parts needs: update your location - at least what state your in, that's helps folks decide if it's even worth discussing large parts like wheels/fenders/etc. there's also a parts wanted forum, you could post a separate thread there for brat parts indicating exactly what you're looking for. Link to comment Share on other sites More sharing options...
edrach Posted February 8, 2011 Share Posted February 8, 2011 seem like need to new repair of synchronizer ring or sleeve because of there already worn out into transmission. :-\Redline 75W-90NS will often save worn synchros. I had over 250K on our old Impreza and the NS gearoil eliminated all the synchro crunch. How old is your transmission; very unusual for 4th gear synchro to be worn without 2nd or 3rd showing symptoms. Link to comment Share on other sites More sharing options...
